Error code E 08 6 What is this? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ozonelayer, this thread has received 2 replies and been viewed 2176 times.
post #1 of 3 (permalink) Old 07-14-2010, 04:10 AM Thread Starter
A couple of days ago my 97 F350 Ford 7.3 L Turbo Diesel had this problem. I turned the key on and the speedo went from 0 mph to 90 mph then back to 0 mph. In the mileage box it said E 08 6. Then start the truck and it does the same thing.. Then driving down the road the speedo stays on 0 mph.. What is this code E 08 6???
ozonelayer is offline
post #2 of 3 (permalink) Old 07-14-2010, 12:42 PM
is here and there.
Rcannon's Avatar
Images: 11
make sure the reset button is not stuck in.
Rcannon is offline
The Following User Says Thank You to Rcannon For this addition to TDG:
ozonelayer (07-16-2010)
post #3 of 3 (permalink) Old 07-16-2010, 01:47 AM Thread Starter
Smile Help worked
Rcannon, Thanks for that infor.. I called the Ford dealer and they didn't know what the E 08 6 code was.. They were going to take the instirment pannel off and check it that way.. It would of cost probably $200 to get out of there..
You said to check the Reset button and the other button, I think it says select.. I played with them for a little while.. HEY guess what.. That was it... I fixed it for FREE... Thanks
Code 32 - EGR Circuit Error wawhiker 6.5L Diesel Engine 7 08-07-2010 03:29 AM
DTC Error Code Confusion Harcati 2003-2007 6.0L Power Stroke 1 10-21-2009 12:47 AM
error code Stroked Ford 1994-2003 7.3L Power Stroke 5 02-18-2009 10:37 PM
P1689 ERROR CODE - Cause of code Found! Mopar1973Man 5.9L Cummins (1998.5-2002) 6 02-02-2009 03:36 PM
Error Code: PO 308 JoeDirte 1994-2003 7.3L Power Stroke 9 03-09-2008 12:55 AM
