Rear axle bearings - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fedman, this thread has received 2 replies and been viewed 1697 times.
post #1 of 3 (permalink) Old 07-15-2010, 03:07 PM Thread Starter
Rear axle bearings
Replacing rear pads, rotors and calipers on my 02 F350 dually. Should the bearings be packed with wheel bearing grease or are they lubricated with differential oil. There was no grease on them when I removed the hubs. It is a Dana 80 rear end. Thanks for any help.
08' F350 Lariat DRW
fedman is offline
post #2 of 3 (permalink) Old 07-17-2010, 09:00 PM
Super Moderator
John_G's Avatar
Gear oil only. Pre-lube by pouring a smallish quantity of oil over the bearings before you install them, then final lube is achieved by jacking one side 6" higher then the other for 1 - 2 minutes and switching sides. Be sure to check differential level before and after adding as needed.
I vote for LIBERTY!
John_G is offline
post #3 of 3 (permalink) Old 07-20-2010, 03:55 AM
hayjayhorses's Avatar
I like to put a little grease on the bearings but definitely squirt some gear oil in the hub (about an once) before you put it back on the spindle
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
How Difficult Is It To Change the Rear Differential Bearings? Deezle_Dog 2003-2007 6.0L Power Stroke 3 10-07-2009 01:28 AM
New HD rear axles and rear axle parts TonyBurkhard Whats Been Sold 6 11-08-2007 03:17 AM
Unit hub bearings, axle shaft seals, paulkeith General Ford Truck and Excursion 3 11-05-2007 12:31 AM
Dana 70 axle shafts, diff and bearings Squatch Supporting Vendors Forum 4 04-02-2007 06:28 AM
04-16-4 Rear Axle Popping/chatter Noise - Dana 80 Model Dual Rear Wheel (drw) Squatch Ford Oasis requests 0 03-23-2007 12:56 PM
