Even ford doesnt know - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PennyPinchingPowerStroke, this thread has received 22 replies and been viewed 8252 times.
post #1 of 23 (permalink) Old 07-19-2010, 04:49 AM Thread Starter
Angry Even ford doesnt know
So the other day I got in my 2000 7.3 truck and hit the key and when it fired it loped til it died. Turned the key off then back on and waited a few seconds before i cranked it over and she fired right up. If i get in and hit the key right away she lopes and dies but if i wait bout 5 seconds she takes right off. Hot or cold doesnt matter. When it lopes and i give it throttle it will slowly climb to the top, say in about 2 minutes, let off it lopes til it dies. Turn the key off then back on and at 5 mississippi im on my way. No lack in power or anything. Not throwing any codes while it lopes or runs normal. Any ideas???
PennyPinchingPowerStroke is offline
post #2 of 23 (permalink) Old 07-19-2010, 05:15 AM
balz out's Avatar
some type of fuel or timing problem?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
The Following User Says Thank You to balz out For this addition to TDG:
post #3 of 23 (permalink) Old 07-19-2010, 01:32 PM
4cstr's Avatar
Images: 35
Do you still have the 10k mod hooked up? If so...disconnect that and see if the problem persists.
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
post #4 of 23 (permalink) Old 07-19-2010, 04:21 PM
bushpilot's Avatar
the cold start sounds like a glow plug issue.
but the non idle makes me think its fuel delivery issue...fuel filters, fuel pump/pressure, hpop ?
Don R.
Truck Audio,
bushpilot is offline
The Following User Says Thank You to bushpilot For this addition to TDG:
post #5 of 23 (permalink) Old 07-21-2010, 06:48 AM
CSIPSD's Avatar
Dirty IPR... Clean it, and the issue should go away.
Also, check your ICP sensor, if there is oil in the connector replace the ICP sensor.
CSIPSD is offline
The Following User Says Thank You to CSIPSD For this addition to TDG:
post #6 of 23 (permalink) Old 07-21-2010, 09:38 PM
TDG MAFIA MEMBER #77
TooLoudTooBad's Avatar
Same thing applies to the IPR. If there is oil in the connector, replace it and the IPR. (Get them off Ebay unless you have a good friend at the parts counter or deep pockets).
TooLoudTooBad is offline
The Following User Says Thank You to TooLoudTooBad For this addition to TDG:
post #7 of 23 (permalink) Old 07-22-2010, 05:01 AM
hayjayhorses's Avatar
my high mileage powerstoke with start lope and stall if I let them sit for a few weeks. It is because the HPOP reservoir drains back.
I just crank it hold it to the floor and keep the idle high for a a minuet and it's fine.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
The Following User Says Thank You to hayjayhorses For this addition to TDG:
post #8 of 23 (permalink) Old 07-22-2010, 05:16 AM
bushpilot's Avatar
the HPOP reservoir can NEVER drain back !
if the HPOP is leaking at the STC connector youll suffer EXTENDED cranking
times to start <because it takes longer/cranking to build the minimum 500 psi>.
eventually a "leaking" HPOP will leave you STRANDED !
Don R.
Truck Audio,
post #9 of 23 (permalink) Old 07-22-2010, 03:43 PM
OK???
Then why is it when some of these high mileage 7.3 sit for a few weeks, you unscrew the oil pressure sensor off the top of the HPOH reservoir drop a screw driver down the in the HPOP reservoir and there is a drop of oil on the end of the screw drive? It doesn't leak out on the ground.
The HPOP reservoir can drain back, I have seen many trucks that wouldn't start unless you fill the HPOP reservoir with oil.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #10 of 23 (permalink) Old 07-22-2010, 03:48 PM
Any ideas???
How long did the truck not run for?
Did you by any chance watch your oil pressure gauge?
If the lope stops about the same time your oil pressure gauge jumps to "normal", that is your HPOP reservoir filling up.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
This doesnt sound right... blackcloudCTD95 The Parking Lot 51 01-09-2009 12:51 AM
Truck Tries To Start But Doesnt shane 2003-2007 6.0L Power Stroke 6 04-01-2008 02:06 PM
doesnt this look like fun? SSpeeDEMONSS The Parking Lot 5 02-03-2008 10:45 PM
doesnt want to go. bigdaddy1 5.9L Cummins (1998.5-2002) 2 07-30-2007 06:29 AM
Doesnt this piss you off!!!! diesel dan The Parking Lot 23 07-27-2006 12:48 AM
