SAFE EGT TEMP'S? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JIMS 03 73, this thread has received 14 replies and been viewed 19909 times.
post #1 of 15 (permalink) Old 07-19-2010, 07:01 PM Thread Starter
JIMS 03 73's Avatar
SAFE EGT TEMP'S?
So for you guys with tuner/chips, Where do yu have your temp gauge mounted and when do you back out of it? What do you guys consider to hot to hold it? Obviously diffence from short runs (truck pull, drag race) to long uphill towing. Whats everyones rule of thumb? Thanks
Charcoal Gray 2003 F-350 7.3L
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
DIY INTAKE AND NO CAT
EDGE EVO. W/ POD
JIMS 03 73 is offline
post #2 of 15 (permalink) Old 07-20-2010, 04:36 AM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
i have my gauges mounted in the a pillar with the egt on the bottom and i have had it upwards of 1400* but thats as high as i have ever let it go and it only stayed there for a second or two but that was as far as i pushed im sure it would have only kept climbing but for me 1400 is as high as ill ever let it go before i roll out of the throttle. but they say that at 1400 things can start to go wrong some will say a little more some will say less. but it also depends on the ammount of time you let it stay that high.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #3 of 15 (permalink) Old 07-20-2010, 12:24 PM Thread Starter
JIMS 03 73's Avatar
Where did you put the actual probe though? in the bend of the mainfold at the back? Thats where i put mine and i always start to watch it heavy when it hits 1000*. I guess the four digits is what makes me nervouse....
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
EDGE EVO. W/ POD
post #4 of 15 (permalink) Old 07-20-2010, 02:06 PM
BillsFan's Avatar
Mine is near the bend too. I start to watch at 1000* but don't start backing off until it crests 1200*. I have held 1000-1100* pulling heavy up hill for short periods but usually try to keep it under 1000* - she's old after all, I don't want to tempt fate.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #5 of 15 (permalink) Old 07-20-2010, 09:56 PM
ccp
ccp's Avatar
sorry i wasnt thinking at all at at midnight when i posted that, mine is in the pass side manifold in the center of the bank i wanted it as close to the cyliners as possible so my temps are probably different than everyone elses.
custom intake
dp tuner
ccp is offline
post #6 of 15 (permalink) Old 07-21-2010, 02:30 AM
4cstr's Avatar
Images: 35
I have mine on the drivers side toward the bend upwards. Figured I was sampling all the cylinders on that side putting it there.
I'll let my early 99 climb to 1250* before I begin to back out of it. This weekend I tickled 1400* for a mere second then got out of it. That is the warmest I have ever let her run. Most of the time while towing I run in the 800* to 1100* range.
~Dave~
4cstr is offline
post #7 of 15 (permalink) Old 07-21-2010, 02:40 AM
Safe SUSTAINED pre-turbo EGT's should be limited to less than 1250 degrees.
You can go higher than 1250 in short bursts such as drag racing or sled pulling. But don't tow a trailer up a mountain pass at over 1250 degrees, or you'll run into trouble.
I've personally seen 1500 degrees with an exhaust leak and a broken wastegate actuator. Fixed those problems in a hurry.
Pocket is offline
post #8 of 15 (permalink) Old 07-21-2010, 06:44 AM
CSIPSD's Avatar
Its amazing what the correct information will do for ya!
CSIPSD is offline
post #9 of 15 (permalink) Old 07-21-2010, 05:39 PM Thread Starter
JIMS 03 73's Avatar
Thanks guys. Makes me feel a lot better. I was alwys wondering about where to let out of it. Do you guys notice on the temp when you air filter gets dirty. Mines seemed a little hotter lately. Thinking its about due. In the tow setting Im probably in the 800-1100 area as well. high setting jumps it up in a hurry though if not carefull. Thinking its time to straight pipe it. and try to keep her cool.
SRW SC
SINGLE'S #197
RIDIN DIRTY #58
EDGE EVO. W/ POD
post #10 of 15 (permalink) Old 07-21-2010, 10:55 PM
ccp
ccp's Avatar
the air fuel ratio has a lot to do with it, of course in the "high mode" its getting more fuel and more air and like a oxy torch but in engine cylinder form, depending on the mix it will be hotter or cooler. how hot the temp outside is also matters cold air is more dense than hot air and effects egt. so long story short i dirty airfilter doesnt move air as efficently and could have that effect on the egt.
custom intake
dp tuner
ccp is offline
safe-key cajuncummins The Parking Lot 29 12-18-2007 01:52 AM
When you think your job is safe... Foxx The Parking Lot 8 10-28-2007 03:32 PM
Is it Safe? supertech671 6.7L Cummins (2007.5-2011) 44 09-01-2007 03:37 PM
How far is safe??? sbusald 5.9L Cummins 12 Valve (1994-1998.5) 9 03-16-2007 01:14 AM
