Higher EGT's and water Temp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by POWER STROKE 99, this thread has received 5 replies and been viewed 1331 times.
post #1 of 6 (permalink) Old 07-22-2010, 02:09 AM Thread Starter
TDG MAFIA MEMBER #71
POWER STROKE 99's Avatar
Hey guys I know its been awhile since i been on the garage but I have been super busy building my house and all the usuall stuff.... ok.... I have been experiencing higher EGT's even after cleaning the the air filter and the water temperature has been higher than normal also....the engine has 270,000 on it and just got back a oil sample anylasis that said lead content was high....I have been pulling a trailer all summer so that may have something to do with that.....any help would be great....
POWER STROKE 99 is offline
post #2 of 6 (permalink) Old 07-22-2010, 05:40 AM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
how many ppm of lead? under 14ppm isnt anything to worry about,or so im told,but it could be a bearing going.it could be a lead smear from a bearing having some crud getting in there, it will get along for awhile with scored bearings. thats just my two cents hope its of some use.
as for temp issues, is it hotter than normal outside, i know its been way hotter than normal this year in sw ohio and my egts, trans temp and water temp have all been going up.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #3 of 6 (permalink) Old 07-23-2010, 02:16 AM Thread Starter
yes it is higher than 14, I will do another sample and check again.....as for temperatures yes it has been hot but it started before that.
post #4 of 6 (permalink) Old 07-23-2010, 02:59 AM
4cstr's Avatar
Images: 35
What thermostat do you have installed? I was running the 203* stat that Riley sells, but noticed that my fan was constantly kicking on/off during the summer towing season. I dropped back down to a stock 195* stat...and it has made a huge difference in the fan operation as well as my coolant temps.
Also...when was the last time your stat was changed? Perhaps its getting sticky and not opening all the way when it should.
~Dave~
4cstr is offline
post #5 of 6 (permalink) Old 07-26-2010, 11:31 PM
CSIPSD's Avatar
Sounds like a turbo issue to me, but the copper levels would be high as well.
CSIPSD is offline
post #6 of 6 (permalink) Old 08-16-2010, 02:59 AM Thread Starter
I think you may be correct on the stat....I'm gonna change it and see what happens......also on the turbo it was rebuilt by HTT about 3 years ago....... do you think I could have a cracked injector nozzel?
higher EGT's? Turbo Issue? NCfarmboy 2003-2007 6.0L Power Stroke 2 07-17-2010 02:37 PM
higher egt's and lower boost after EGR block off plates, normal? fearsno1 2008-2010 6.4L Engine Tuner Forum 4 12-30-2009 01:23 AM
EGR block off = higher EGT's ? harry6.0 2003-2007 6.0L Power Stroke 5 01-04-2008 02:29 AM
Higher EGT'S POWER STROKE 99 1994-2003 7.3L Power Stroke 2 06-14-2007 07:57 PM
water temp what it should be? bruisnit 2003-2007 6.0L Power Stroke 1 05-09-2006 03:08 AM
