Oil Change, now no start... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3rambaler, this thread has received 3 replies and been viewed 1258 times.
post #1 of 4 (permalink) Old 07-25-2010, 03:12 PM Thread Starter
7.3rambaler's Avatar
i just changed my oil and filter, put 3 1/2 gallons back in..the oil level is over but it usually goes down when you run the engine after you first change the oil. so what could be the problem? its not low, and it was running perfect before i changed the oil.
2000 F-250 7.3L. Ext Cab. Short Box.
Dp Tuner 80 eco-tune
Fully Built Tranny with Triple Disk Converter
AFE stage 2, 4in from turbo back stright pipe, foil Delete, X-Wheel Gauges-tranny-pryo-boost
7.3rambaler is offline
post #2 of 4 (permalink) Old 07-25-2010, 04:43 PM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
the hpop has probably sucked up some air it happened to me i just had to crank on it til it pushed the air out.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #3 of 4 (permalink) Old 07-25-2010, 05:40 PM Thread Starter
thanks man but it turned out to be the started relay. guess it just went bad randomly
post #4 of 4 (permalink) Old 07-25-2010, 11:01 PM
ccp
ccp's Avatar
mine is doing that now but only when its hot
custom intake
dp tuner
ccp is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
'89 F250 won't start after filter change Bigfoot is real 7.3L and 6.9 IDI (Pre 1994) 9 01-22-2008 01:51 AM
first oil change and fuel filter change? chvylac 2003-2007 6.0L Power Stroke 10 12-03-2006 09:26 AM
03 6.0, won't start after filter change. V895-ST280 2003-2007 6.0L Power Stroke 14 07-22-2006 11:04 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
