truck runs like its running out of fuel - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ldwzlaw, this thread has received 12 replies and been viewed 8251 times.
post #1 of 13 (permalink) Old 08-20-2010, 08:00 PM Thread Starter
Levi
ldwzlaw's Avatar
the other day after while running my truck pretty hard in the mud and it began to run like it was running out of fuel like its getting just enough fuel to stay running real rough.. i took the programmer off and it runs the same..it will drive but it has no power at all..and the check engin light is on... i replaced the cam sensor and all the wiring harnesses going to injectors are all new and the fuel filter is good.. the only thing that i could come up with is its the fuel pump on top of the motor.. does anyone have any other ideas before i change it because id hate to spend the time replacing it and not fix the problem..
-1995 F350 7.3 liter diesel extended cab dually, 292000 miles, K&N cold air intake, 3 inch down pipe, straight pipe, bullydog 6 position chip, a trans and boost gauge.
-1996 f250 single cab long bed 4x4, k&n cold air intake, ts chip, straight pipe, 211,000 miles, 6in lift, 35in tires
ldwzlaw is offline
post #2 of 13 (permalink) Old 08-20-2010, 08:30 PM Thread Starter
Levi
ldwzlaw's Avatar
never mind i think i fixed the problem when i went and bought the fuel pump i also bought the fuel pump relay for the heck of it and put the new relay on and started up and ran fine so lets hope thats all that was wrong!
ldwzlaw is offline
post #3 of 13 (permalink) Old 08-20-2010, 09:34 PM Thread Starter
Levi
ldwzlaw's Avatar
okay the relay wasnt the problem im completely lost again.. i put the new relay on and it started and ran normal i pulled it forward and still ran fine well went to take it for a test drive and made it 100 feet and then it started to run like it didnt have fuel... would the fuel pump intermit like this or is it something else
ldwzlaw is offline
post #4 of 13 (permalink) Old 08-20-2010, 10:06 PM Thread Starter
Levi
ldwzlaw's Avatar
i plugged my programmer in and it gave me this error code.. P0603- internal control module keep alive memory (kam) error.. not sure what it means or if it helps
ldwzlaw is offline
post #5 of 13 (permalink) Old 08-20-2010, 10:43 PM Thread Starter
Levi
ldwzlaw's Avatar
alright i had a had a good idm in the shop so i put it on the truck just for the heck of it and started it up and ran the same.. then i pulgged the old one back in and started it up and it ran fine again this time i drove bout 1/4 a mile and then it started running rough again.. i dont think its the fuel pump any more.. could use some ideas? anyone?
ldwzlaw is offline
post #6 of 13 (permalink) Old 08-21-2010, 12:05 AM
its cause your truck is soft as charmin
cdub6761 is offline
post #7 of 13 (permalink) Old 08-21-2010, 10:34 PM Thread Starter
Levi
ldwzlaw's Avatar
alright i changed the fuel pump today and i started it up and it ran fine drove it down the road started to run like it had no fuel very little power and very slow as soon as i pulled up to the shop it started to run fine.. so i drove it down it started to run bad again then good i plugged the programmer in when it was running like crap and these codes came up p1280 icp low.. p0472 exh low... p0198 engin oil temp high and when it was running good i got p1111 air intake..
im lost.. is it the idm or pcm or senors or is my wiring harness shorting out somewhere? anyone have any ideas...?
ldwzlaw is offline
post #8 of 13 (permalink) Old 08-22-2010, 03:56 AM
F350-6's Avatar
Check your fuel pressure at the schraeder valve. Seems like there's a screen on the side of the fuel bowl on the OBS that has to be cleaned when the symptoms are a fuel restriction.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
The Following User Says Thank You to F350-6 For this addition to TDG:
ldwzlaw (08-24-2010)
post #9 of 13 (permalink) Old 08-23-2010, 04:58 AM Thread Starter
Levi
ldwzlaw's Avatar
fuel pressure was good... so i think any thing mechanical i have ruled out... i dove it today and it didnt run crappy for a good 10 minutes then to startd running with same problems for like 30 sec then normal and it would just run like crap ever couple minutes.. the whole time we were getting all kinds of trouble codes that didnt even make since on the programmer ... well i did some research and im pretty sure my edge screwed my pcm up so im going to got to the dealer and get it flashed and hope that fixes the problem..
ldwzlaw is offline
post #10 of 13 (permalink) Old 08-23-2010, 09:07 PM Thread Starter
Levi
ldwzlaw's Avatar
i got the pcm flashed and i dont think it was the problem i drove to the dealership without a single problem with the programmer on... got there put the truck back to stock and then had the pcm flashed and then stopped by the auto parts store and bought some diesel clean and then drove it around for a good 10 minutes and it start running real crappy again for like 30 sec and then back to normal and then i drove it for another 5 minutes and ran fine..
it seems like its getting better but im still not to sure whats going on.. im thinkin about trying to replace the cam sensor again.. anyone have any ideas yet?
ldwzlaw is offline
fuel filter light.. truck running funny.. need help ldwzlaw 1994-2003 7.3L Power Stroke 5 07-20-2009 12:04 AM
Innovative Diesel Truck runs [email protected] Fuel Only InnovativeDiesel 2003-2007 6.0L Power Stroke 28 05-17-2009 06:39 PM
running truck out of fuel jeffro22 2003-2007 6.0L Power Stroke 8 01-16-2009 07:13 PM
Truck Runs Then Dies 01CUMMINS24 5.9L Cummins (2003-2007.5) 5 12-03-2007 03:34 PM
Replaced fuel filters, truck runs like crap!!! 6LTR4LIFE 2003-2007 6.0L Power Stroke 8 05-06-2007 10:57 PM
