Running rough and engine light comes on - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JAW, this thread has received 9 replies and been viewed 5233 times.
post #1 of 10 (permalink) Old 12-30-2010, 12:46 AM Thread Starter
JAW
Question Running rough and engine light comes on
I am new here to this site. A month ago I bought a 2003 7.3L F-250 and approximately every 700 miles while running it will start running very rough and lose power and check engine light comes on. I pull over and restart the truck and runs fine until it happens again. One code that pulls up is 603. 2 weeks after I got it I put a TS Performance chip on but it has happened before and after. Any ideas?
2003 7.3L F-250, 4WD, 4-door, short bed, 4" straight stainless pipe, TS Performance chip, K&N Filter with stock air box.
JAW is offline
post #2 of 10 (permalink) Old 12-30-2010, 01:55 PM
bpogue's Avatar
What are you using to get that code? That doesn't sound like a regular DTC code from our trucks.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 10 (permalink) Old 12-30-2010, 02:53 PM Thread Starter
JAW
its one of the newest scanners that snap-on makes but i dont know which model. just checked agian two other codes came up 1316 and1211 the 603 code wasnt there this time. i dont know all that much about it but wouldnt it be a sensor or loose connection since it resets itself and runs perfect after restarting?
JAW is offline
post #4 of 10 (permalink) Old 12-30-2010, 06:37 PM
blageurt's Avatar
maybe your UVC harness is loose and needs to be clipped back in...
95 E350 Cargo , BB shim
DP flashed 60 Tow PCM , B&M Aluminium Pan , Transgo Shift Kit , Autometer Triple Pod avec Guages , Cat sleeps with the fishes, Dana 70 FF 3:55 , Timbrens SES Kit
Stage I injectors / IDM mod coming soon
blageurt is offline
post #5 of 10 (permalink) Old 12-31-2010, 01:24 AM
bpogue's Avatar
Sounds like a good possibility.
2003 Takeuchi TL150
bpogue is offline
post #6 of 10 (permalink) Old 12-31-2010, 04:51 PM Thread Starter
JAW
Ill check on that, thank you!
JAW is offline
post #7 of 10 (permalink) Old 01-02-2011, 01:45 AM
F350-6's Avatar
P1316 is almost always a loose UVCH. P0603 is a common code when you're running a chip. You can ignore that one. P1211 is also likely chip related. You'll see this one in the future after leaning hard on the skinny pedal. The CEL will light up briefly, but there will be no performance issues. Again, it's normal with a chip so ignore it.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #8 of 10 (permalink) Old 01-02-2011, 03:27 AM Thread Starter
JAW
Thank you for your help! I've check the driver's side which seemed okay so I'll check the other side. When I get this problem repaired I'm considering getting a cold air intake. Considering Banks because they advertise the coldest air, but AFE stage 2 says theirs adds 50 HP and 112
FTLB torque. This sounds high to me. I think I like Banks better. Any suggestions?
JAW is offline
post #9 of 10 (permalink) Old 01-03-2011, 02:12 AM
F350-6's Avatar
Originally Posted by JAW View Post
Any suggestions?
Yes, stop believing all the advertisements you read. As for coldest air or most HP, all the good ones are pretty close on the actual dyno. AFE is a good filter. So is banks, but banks stuff tends to be overpriced. S&B also makes a good filter which some say does a better job in the filter dept. Many just run a 6637 filter and save a couple of hundred.
Do some reading and pay attention to what others are using and ask questions on what they do and don't like about it. You'll learn a lot by just reading here.
Chris
F350-6 is offline
post #10 of 10 (permalink) Old 01-05-2011, 03:22 PM Thread Starter
JAW
Thanks, ill do that,good suggestion!
JAW is offline
2002 7.3 - Check engine light and rough running Rev J Wright 1994-2003 7.3L Power Stroke 30 09-18-2009 02:53 AM
running problems with check engine light on 1995nicholas 1994-2003 7.3L Power Stroke 3 04-01-2009 01:52 AM
Check Engine light on & rough running dieselbrad 1994-2003 7.3L Power Stroke 2 10-31-2007 12:49 AM
Engine running rough Roughneck 5.9L Cummins (2003-2007.5) 15 05-25-2007 08:38 PM
engine running rough fordrules75 1994-2003 7.3L Power Stroke 0 11-06-2006 01:59 AM
