Glow plug relay doesn't work sometimes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RLU_tech, this thread has received 12 replies and been viewed 12497 times.
post #1 of 13 (permalink) Old 01-03-2011, 01:49 AM Thread Starter
sometimes when I start my truck cold, my glow plug relay will not turn on to heat the glow plugs. I usually cycle the key a few times till I see the "wait to start" light dim a little telling my the relay has clicked. Once that happens I wait for the light and the truck fires up. Could this be a bad relay ground or a bad signal from the PCM?
1997 F-250 Super cab/Short bed 4x4 XLT
7.3L PowerStroke Diesel/ZF-5 Standard Trans.
DiamondEye 4" turboback exhaust/6" tip (no muff or cat)
RLU_tech is offline
post #2 of 13 (permalink) Old 01-03-2011, 02:01 AM
F350-6's Avatar
Could easily be a bad relay. They can get a burnt spot on the disc inside that doesn't arc the current properly.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #3 of 13 (permalink) Old 01-03-2011, 02:35 AM
A freind of mine had the same problem the heads up display tells the pcm the outside tempature, that controls the glow plug on time. if you have heads up diplay that does not work, they are rebuildable.
Johnp3 is offline
post #4 of 13 (permalink) Old 01-03-2011, 11:29 PM Thread Starter
Well the Glow plug relay is only a few months old. I will have to look into the heads up display.
RLU_tech is offline
post #5 of 13 (permalink) Old 01-04-2011, 12:19 AM
We got the name of the guy that rebuilds them from a wrecking yard in OMAK Washington, state Randy's, I believe was the name.
Johnp3 is offline
post #6 of 13 (permalink) Old 01-04-2011, 06:51 PM
You can tell if the relay is working, you'll see the amp meter drop from 12 to 8 when turning the key to the start position without hitting the starter. If it only drops to like 10 amps, you're not getting power out of the relay to the plugs. I just went through this in Novmber of all things, relay only had 3k miles on it and was bad....good luck
1997 F350 4WD CREW XLT, LB,SRW, 7.3 AUTO
DARK GREEN
AFE CAI, 4'' MRBP 409 SS exhaust, Superchips
3 inch R+D HD spring lift
137K miles 35" BFG-AT
Baldguy01 is offline
post #7 of 13 (permalink) Old 01-05-2011, 01:21 AM Thread Starter
Well I pulled it in the shop after work tonite and tried checking some things out with the test light but it wouldn't act up...go figure. So I removed the GPR and cleaned the out of the ground surface which touches the relay. We'll see what happens tommarow.
RLU_tech is offline
post #8 of 13 (permalink) Old 01-06-2011, 03:30 AM
Do Not replace with a stock relay, order a Stancor 902 relay, 12V 200A continuous duty. about $52 from either mouser or alled elec. the standard relay is only intermitent use and will not last. I replaced mine with a 250A severe duty relay.
Vince
e99 F350
DIY intake, exhaust
PHP FU, 6.0 trans cooler.
countryraised is offline
post #9 of 13 (permalink) Old 01-06-2011, 03:38 AM
plainredtruck's Avatar
Images: 11
I had a Stancor.
It lasted less than 12 months.
I had the Napa GPR 109 and it lasted less than 6 months.
I went back with the International part # since it's cheaper than the other two.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #10 of 13 (permalink) Old 01-06-2011, 06:04 PM
I have not tested it or am not sure on the Ford but a lot of circuits that are PCM controled, are designed to run at a low amperage and problems can happen when a larger draw activation circuit is used. Just a thought!
Johnp3 is offline
glow plug relay? Stroker99 1994-2003 7.3L Power Stroke 0 12-11-2009 03:31 AM
Glow plug relay... CSIPSD 1994-2003 7.3L Power Stroke 7 05-08-2009 09:14 PM
Glow plug relay powerstrokin94 1994-2003 7.3L Power Stroke 9 12-19-2007 12:59 AM
Glow Plugs or Glow Plug Relay BillsFan 1994-2003 7.3L Power Stroke 6 12-19-2007 12:51 AM
glow plug relay kkdiesel7 1994-2003 7.3L Power Stroke 4 12-07-2007 03:29 PM
