97 f350 tranny temp issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97flatbed7.3, this thread has received 6 replies and been viewed 1356 times.
post #1 of 7 (permalink) Old 01-09-2011, 12:59 AM Thread Starter
97flatbed7.3
I have a 1997 f350 7.3L it has stage one injectors, airraid intake, mbrp downpipe, 4" dual straight- pipe and a ts 6 position chip. I put all the upgrades in about the same time (may 2010) everything has been running great. The past month i noticed my tranny temp has been 180- almost 200. Truck still runs great when at this temp. Wondering if its an issue, if so what can I do to fix the problem? I was told to get a bigger tranny cooler.
97flatbed7.3 is offline
post #2 of 7 (permalink) Old 01-09-2011, 05:17 AM
4play's Avatar
If you have had a guage on it for awhile and it used to run cooler then I might be concerned, but thats around the normal temps for the factory cooler setup.
If it is running hotter than normal, there are numerous possibilities but I would make sure the cooler lines are not damaged/restricted, and trans cooler is clean and airflow path un-obstructed.
If you want cooler temps you will need to upgrade the cooler.
4play is offline
97flatbed7.3 (01-19-2011)
post #3 of 7 (permalink) Old 01-11-2011, 03:54 PM Thread Starter
97flatbed7.3
Thanks a lot, when I get some time to work on it ill try the bigger tranny cooler and check all hoses. Hopefully that'll do the trick
post #4 of 7 (permalink) Old 01-12-2011, 01:22 PM
Mutley's Avatar
Would synthetic tranny oil along with a larger cooler be the best option? I'm running synthetic in my 5 speed (Mobil 1) and there's an obvious difference in the way it works over std oil but don't know about temp variances.
Mutley is offline
post #5 of 7 (permalink) Old 01-14-2011, 01:30 AM Thread Starter
97flatbed7.3
It wouldn't hurt to try. I'm running what the tranny calls for, nothin special
post #6 of 7 (permalink) Old 01-18-2011, 07:15 PM
Mine has always ran 195 or so, mine though doesnt go through the stock cooler though, it goes from trans and straight to an add on RV cooler thats about 12x12 and straight back to trans, and has an electric 12" fan that i run in the summer (always on in summer and unhooked in winter.
2007 Dodge Ram 2500 lonestar 5.9 CRD, 6-Speed
full MBRP 5" turboback, S&B intake, FASS, ISSPRO gages, BD Diesel steering stabilizer, Tough country leveling kit, Air lift Rear leveling, Southbend clutch, XD Hoss 18" wheels, Nitto Trail grapplers, Satellite radio, LED tailights
1997 ford f-250 POWERSTROKIN auto ex cab LB, homemade intake, superchips programmer, trans, egt, boost gages, tripple a pillar pod (daily driver)
2005 dodge SRT-4 2.4turbo ED hard pipes, aem short ram, MPx 3" turboback, HKS SSQ BOV, AEM wideband, Motegi Mr7 18"rims custom painted (weekend racer) [email protected] 107
2001 suzuki GSX-R600 K&N, Two bros. exhaust, neons, polished frame, (sumertime DD, and track toy)
11.000 @ 127
2006 raptor 700R blue dirt toy
2006 raptor 700R white dirt toy
just visiting is offline
The Following User Says Thank You to just visiting For this addition to TDG:
post #7 of 7 (permalink) Old 01-18-2011, 07:26 PM Thread Starter
97flatbed7.3
I'm pretty sure mine is the same as yours (just visiting). I am going to doth bigger tranny cooler and do the BD valve body tranny kit in a couple weeks. I've looked into it and the Bd valve body kit beefs up the tranny quite a bit and lower the temps quite a bit
Engine temp and cooling fan issues. mowtown 2008-2010 6.4L Power Stroke 7 10-15-2010 10:59 PM
tranny temp jordan_labelle 2003-2007 6.0L Power Stroke 3 12-01-2009 04:24 AM
Tranny Temp?? imported_99powerstroke 1994-2003 7.3L Power Stroke 19 04-03-2007 03:47 AM
What temp should the tranny be? 75867586 2003-2007 6.0L Power Stroke 5 07-26-2006 12:10 PM
Tranny Temp jeffro22 2003-2007 6.0L Power Stroke 22 03-06-2006 06:51 PM
