94 7.3L Intermittent Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RanchTruck, this thread has received 3 replies and been viewed 1402 times.
post #1 of 4 (permalink) Old 02-10-2011, 04:27 PM Thread Starter
Krazy 8 Livestock
Hello Ya'll, I have a 1994 F350 7.3 205,000 miles all stock engine. Problem is intermittent start. One of the times it decided to run I performed a commpression test. 285-300 psi. I also tested all glow plugs, Ohmed the valvecover wiring for contenuity. All good.
When it doesn't start. You cannot smell burnt deisel at exhaust when cranking engine.
I think I've narrowed it down to three things when it does not start. The ICP sensor/wiring, HPOP pressure out of specs, or the PCM not talking to the IDM. Am I on the right track? Or am I overlooking something? Does anybody know the specs on the ICP and the HPOP?
Any help is appreciated.
RanchTruck is offline
post #2 of 4 (permalink) Old 02-12-2011, 01:05 AM Thread Starter
Krazy 8 Livestock
Fixed it. Easy Fix.
post #3 of 4 (permalink) Old 02-12-2011, 02:44 PM
Mutley's Avatar
Well???? What was it???? How'd ya fix it????
Mutley is offline
post #4 of 4 (permalink) Old 02-12-2011, 10:12 PM Thread Starter
Krazy 8 Livestock
Corrosion at PCM connection.
Intermittent Stalling Harry Nadz 1994-2003 7.3L Power Stroke 7 09-20-2010 07:26 PM
Intermittent problem Rcannon Utility & Farm Tractors 9 10-16-2009 02:13 PM
Intermittent no start foreman1063 1994-2003 7.3L Power Stroke 2 01-22-2008 12:00 PM
Intermittent Los of Power - Help joeycam 5.9L Cummins (1998.5-2002) 7 01-01-2007 09:13 PM
99 intermittent run good run bad big hunter 1994-2003 7.3L Power Stroke 6 12-16-2006 11:30 PM
