new gp and relay still no start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cdwood388, this thread has received 13 replies and been viewed 2212 times.
post #1 of 14 (permalink) Old 02-16-2011, 05:09 AM Thread Starter
I replaced all 8 glowplugs and the relay is working like it should. If I don't plug the truck in it will not start even when its 50 degrees outside. What could my problem be? All the connections under the valve covers are getting power. What should I look at next?
cdwood388 is offline
post #2 of 14 (permalink) Old 02-16-2011, 02:17 PM
Mutley's Avatar
Does it spin quickly? Are the batteries old? You shouldn't have to plug in until well under 30 degrees.
Mutley is offline
post #3 of 14 (permalink) Old 02-16-2011, 02:23 PM
plainredtruck's Avatar
Images: 11
I agree with Mutley - give us some more information on what it's doing.
I would check the following:
1. Batteries
2. Starter
3. Fuel (gelled, filter, pressure)
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 14 (permalink) Old 02-16-2011, 03:18 PM Thread Starter
Batteries are new and the fuel is good. It does seem to spin slower than it should. It may be weak from trying to start it with bad glow plugs. The starter surges when I crank it over it goes fast then slow and so on. It has plenty of juice.
post #5 of 14 (permalink) Old 02-16-2011, 03:50 PM
biz
change your starter. i had the same issue. what a difference it made. and i dont have to plug it in at all anymore. even last week it was 5 degress out and it fired right up.... i was plugging it in for anything below 45..... not anymore.
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo.
biz is offline
post #6 of 14 (permalink) Old 02-16-2011, 07:16 PM
blageurt's Avatar
I would also remove / replace the starter and get it tested ...SuperDuty starters are better than our original ones ...they have more torque
95 E350 Cargo , BB shim
DP flashed 60 Tow PCM , B&M Aluminium Pan , Transgo Shift Kit , Autometer Triple Pod avec Guages , Cat sleeps with the fishes, Dana 70 FF 3:55 , Timbrens SES Kit
Stage I injectors / IDM mod coming soon
blageurt is offline
post #7 of 14 (permalink) Old 02-16-2011, 08:09 PM
ofg
Ditto on the starter. I was chasing a cold start issue as well. Starter seemed to crank fast enough. What happens, is the starter may draw TOO MANY AMPS, and starve the injectors and other systems of voltage.
I would give the batteries a long full charge and swap out the starter and relay switch too.
By the way, check that oil level is full or injectors will not operate.
ofg is offline
post #8 of 14 (permalink) Old 02-21-2011, 02:16 AM Thread Starter
I changed the starter which solved the speed at which it spins but still will not start unless it is warm or i plug it in. Once it is started it runs great like it always has, just hard to start, what should I look at next.
post #9 of 14 (permalink) Old 02-21-2011, 04:40 PM
blageurt's Avatar
glow plug relay ? just because it is working does not mean it is OK...
blageurt is offline
post #10 of 14 (permalink) Old 02-21-2011, 04:58 PM Thread Starter
Its giving out voltage what else do I check
Weird Electrical Issue: Trans/ABS/IDM Relay/Trailer Lights/No Start HoustonPSD 1994-2003 7.3L Power Stroke 0 05-03-2010 04:14 PM
Headlights relay. alex8888 2008-2010 Body & Suspension 3 12-05-2009 10:13 PM
Clicking Relay - Caused no Start AllOut0606 1994-2003 7.3L Power Stroke 8 01-24-2008 10:57 PM
Question about relay tmunoz 1994-2003 7.3L Power Stroke 6 03-04-2007 05:28 AM
Horn Relay Where? fordfanatic69 1994-2003 7.3L Power Stroke 2 01-21-2007 04:05 AM
