Truck has "no go"....again! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Chudybuddy, this thread has received 3 replies and been viewed 1467 times.
post #1 of 4 (permalink) Old 03-03-2011, 01:42 PM Thread Starter
Question Truck has "no go"....again!
Hello,
I have a 01' F350 7.3. Back in January (5th), I had an earlier post on here (Truck had "no go")...ended up having to change inj #6. Truck is back to doing the same without any codes. It does fail the cont test on 2, 4, 8. Pulled valve cover off and then reran the test. This time 2, 4, 6 failed. Replaced valve cover gasket and UVCH last night. Took it for a test drive and it ran great! Jumped in it this morning to go to work and it didnt have any "go" again!
Please any help would be greatly appreciated!
Thank you!
Chudybuddy is offline
post #2 of 4 (permalink) Old 03-04-2011, 05:00 AM
dmd
dmd's Avatar
Check the EBPV, is the exhaust hissing? Just a guess, but I would suspect you
might have tried that already.
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, Tony Wildman 6-pos chip, Custom 4-inch intake, 4-inch turbo-back exhaust, ATS housing, Adrenaline HPOP, BTS Trans, EBPV delete, ITP overboost eliminator, in-tank and pre-pump mod, Heater valve mod
dmd is offline
The Following User Says Thank You to dmd For this addition to TDG:
Chudybuddy (03-04-2011)
post #3 of 4 (permalink) Old 03-04-2011, 05:03 PM Thread Starter
The EBPV has been removed already. Thanks for you suggestion!
Last night replaced the outer pigtail--That didn't do any good. It is still randomly failing the cont. test (2, 4, 8-sometimes 6). When truck is rev'd up to 2g you hear a couple of pops. Its blowing white smoke. It acts like there is air in the injectors!
post #4 of 4 (permalink) Old 03-06-2011, 03:47 AM
hayjayhorses's Avatar
I would try another IDM
see if you can get one from a friend
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
why does my truck run great with a "non programmed" reman ford ficm? mrod67 2003-2007 6.0L Power Stroke 5 01-08-2011 01:56 AM
MBRP 5", 6", 7" and 8" Diameter 18" Long Exhaust Tips dfuser Supporting Vendors Forum 0 08-14-2010 12:08 PM
The "New Diesel Emissions" prevent the use of a "Jacobs" (jake brake) HARLEY6LF250SDU General Diesel 4 01-17-2009 03:53 PM
"Project Drag Truck" sees the Dyno fordt 1994-2003 7.3L Power Stroke 34 10-05-2006 12:32 PM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 08:00 AM
