97 up pipe gasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97flatbed7.3, this thread has received 11 replies and been viewed 6697 times.
post #1 of 12 (permalink) Old 03-05-2011, 05:20 AM Thread Starter
97flatbed7.3
97 up pipe gasket
Alright, don't feel like replacing the up pipes quite yet, was just wanting to replace up pipe gasket. Does anyone know where I can get the gaskets?!
97flatbed7.3 is offline
post #2 of 12 (permalink) Old 03-05-2011, 05:54 AM Thread Starter
97flatbed7.3
Found the beans brass donuts, are these worth the money? Also, is there a gasket where the up pipe mates to turbo? If so, where can this be purchased?!
post #3 of 12 (permalink) Old 03-06-2011, 03:32 AM
hayjayhorses's Avatar
i went to my local NAPA (Rolla Motor parts , Ware, Mass) with an up pipe and found gasser donut gasket (I think small block GM) I went threw the boxes till i found that fit the pipe.
Then i put studs into cast "Y" pipe then used washes and flange nuts to hold them down. While I had them out I header wrapped the down pipes.
Note I did this while I had the trans out.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #4 of 12 (permalink) Old 03-06-2011, 05:13 AM Thread Starter
97flatbed7.3
Thanks hayjayhorses, I found a part number on another forum for the GM donut. It's F17250, this is the part number for napa. Does that sound right? Also, how much of a pain in the *** to remove up pipes with out removing trans?
post #5 of 12 (permalink) Old 03-06-2011, 08:31 PM
Bruno2's Avatar
A big pain.
7.3 psd ,Z-F5 , ARP headstuds , ARP main studs , D-66 dominator Turbo ,EBPV delete pedestal , MBRP 4" straight pipe , Rosewood stg II's , Tony's tunes 6 pos, K&N gen II intake ,comp 910 springs , Hurst line lock . Ford IC, Banks piping kit .
Alpine deck
Rockford Fosgate subs
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
HD leaf springs ,Over sized drive shafts , heavy duty precision u-joints all the way around
B.O.M.B. squad member #39
Singles Club member #251
Walnutter #8
Bruno2 is offline
post #6 of 12 (permalink) Old 03-06-2011, 08:36 PM Thread Starter
97flatbed7.3
But it can be done with out removing the trans?!
post #7 of 12 (permalink) Old 03-07-2011, 09:59 AM
yeah the U-pipes are tough you will need extensions and swivels for you sockets, If the bolt are in bad shape you may have to hammer a 12 point 3/8" socket on the the 10mm hex heads.
you may be able to unbolt the trans cross member and lower the trans a few inches to give you more room. I have done them many time with out taking the trans down. Now when I pull a trans in a 7.3 stroke I take care of the Up pipes whether they need it or not
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
post #8 of 12 (permalink) Old 03-07-2011, 10:15 AM Thread Starter
97flatbed7.3
What do I need to look for on the up pipes as far as in bad shape is concerned? Soot, rust, etc? What does wrapping the up pipes do for the truck? One more question, the donuts go where the y joins the up pipes to the turbo correct? Is there any other gaskets needed?
post #9 of 12 (permalink) Old 03-08-2011, 06:53 AM
Bruno2's Avatar
Here are some pics:
http://www.ford-trucks.com/forums/10...r-dummies.html
I think there are donuts at the top and bottom.
Alpine deck
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
Walnutter #8
Bruno2 is offline
post #10 of 12 (permalink) Old 03-08-2011, 10:19 AM Thread Starter
97flatbed7.3
I found a diagram of the up pipe and turbo system for the 97 7.3, there are only donuts on the top of the up pipes (one on each up pipe). I think I'm going to order the beans diesel brass up pipe donuts. I get off this damn boat march 30 and as soon as I do I'm going to remove the up pipes, wrap the up popes and install new donuts! You guys have been a huge help with everything, ill take pics and post them as soon as I get off work! Thanks again guys
Looking for 4" down pipe and y-pipe replacement BamaPSD 2003-2007 6.0L Power Stroke 0 12-10-2010 07:54 PM
Head Gasket time should I stud it and A/M Gasket it? cdooguy 2003-2007 6.0L Power Stroke 7 04-26-2007 05:36 AM
Removing Flex Pipe on Up-Pipe and Y Pipe hhrecovery 2003-2007 6.0L Power Stroke 27 11-28-2006 11:36 PM
OBS 7.3L Up-Pipe gasket replacement imported_BigGreen 1994-2003 7.3L Power Stroke 6 05-12-2006 01:37 AM
7.3 99-03 stock exhaust complete from down pipe to tail pipe Bella PSD Whats Been Sold 2 03-22-2006 12:21 AM
