IPR location? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tommy vestrat, this thread has received 5 replies and been viewed 8499 times.
post #1 of 6 (permalink) Old 03-09-2011, 05:09 PM Thread Starter
IPR location?
can someone tell me or show me, a pic would be nice, where the IPR is located on a 96' 7.3l
1996 F 250 extended cab,4x4,7.3l auto trans,power adder cone filter, 3.5 inch straight exhaust, DFuser 18k mod.and veggie powered.
tommy vestrat is offline
post #2 of 6 (permalink) Old 03-09-2011, 06:35 PM
Sheep Shearer
Talyn's Avatar
Assuming you know where the Hpop Res is,
Standing at the front of the motor, its on the drivers side in front of that down below the Hpop. There is a wire going to it.
You can see it if you crawl up on the motor and look between the Fuel bowl and the Hpop on the drivers side.
Talyn (AKA: William) - Resident Sheep Shearer
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, ZF5-S42.
Rosewood 160cc Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic, 140V IDM.
Originally Posted by RubberDuck
But if you don't make time for friends, and fun, what's it all worth.
Talyn is offline
post #3 of 6 (permalink) Old 03-10-2011, 06:06 PM Thread Starter
gotcha! i must be blind. truck has been running rough on s/u, and pumping black smoke. i cleaned the plug with contact cleaner, also noticed that the recepticle on the ipr was kinda loose. but when i started it up it ran good and smoke was not as bad. however it still smokes blue smoke for about a mile until the engine is warm. any ideas? somebody?
post #4 of 6 (permalink) Old 03-10-2011, 07:35 PM
4cstr's Avatar
Images: 35
If the smoke goes away after a mile or so, it most likely is unburnt fuel in the cylinders. When the temperature gets warm enough for a complete burn, the smoke goes away.
~Dave~
4cstr is offline
post #5 of 6 (permalink) Old 03-11-2011, 02:38 PM
Sheep Shearer
Talyn's Avatar
Clean the EGR tube and the EGR sensor.
lets see 96, it should be up in front of the Hpop res.
Unplug it, andpull the sensor out.
use something like weed trimmer string to clean the tube out.
Talyn is offline
post #6 of 6 (permalink) Old 03-12-2011, 07:29 PM
Super Moderator
John_G's Avatar
No EGR equipment on a 7.3L PSD to clean or break, so he won't find it.
I vote for LIBERTY!
John_G is offline
VW TDI location D-Cell_Mekanick Euro-Diesels 31 06-29-2011 02:13 AM
IDM Location? rhpope 1994-2003 7.3L Power Stroke 3 07-14-2009 03:07 PM
Location of the KDP blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 1 02-28-2008 02:42 AM
OBS IDM Location? genie144 1994-2003 7.3L Power Stroke 19 07-16-2007 09:59 PM
PCM location diesel_ram_man 1994-2003 7.3L Power Stroke 5 03-04-2007 12:53 AM
