Oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by neeltburn, this thread has received 13 replies and been viewed 3465 times.
post #1 of 14 (permalink) Old 03-13-2011, 10:45 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Oil leak
Guys,
Neighbor has a 01 F350 7.3L it has a oil leak on the top side of the motor (in the valley). We pulled the IC Pipes and there IS oil inside both sides of the intake or IC pipes. Could this be leaking out of the silicone boots on the intake where the air goes into each head? Also If the turbo is the source of the leak, do we get a rebuild kit? Kenny has one on his site for 74 bucks? The truck is bone stock with roughly 83k on the clock? How hard is a Garret turbo to rebuild? Or do we just put a reman turbo on?
Any advice would be great.
Thanks
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #2 of 14 (permalink) Old 03-13-2011, 10:53 PM
Cummins
kickermatt's Avatar
um the only way the turbo would leak is if the the oiler line is leaking. there could be a leaky valve cover or a breather line could be leaking.
kickermatt is offline
post #3 of 14 (permalink) Old 03-13-2011, 10:56 PM
Cummins
kickermatt's Avatar
so yes most likly a breather tube. its not a big deal you need to buy new clamps.
post #4 of 14 (permalink) Old 03-13-2011, 11:21 PM
Super Moderator
John_G's Avatar
The question is do you have oil BEFORE the turbo? If the crankcase vent is allowing oil into the inlet pipe that would explain it and rebuilding the turbo would be pointless.
I vote for LIBERTY!
John_G is offline
post #5 of 14 (permalink) Old 03-13-2011, 11:33 PM
Cummins
kickermatt's Avatar
thats right! the turbo runs on heat and it only pushes air into the motor and pulls it out. the only part of a turbo that could have anything to do with it would be the oiler.
post #6 of 14 (permalink) Old 03-13-2011, 11:50 PM
4cstr's Avatar
Images: 35
The oil in the CAC tubes could be from the crankcase vent as JohnG mentioned. Is the boot at the top of the drivers side CAC tube oily or greasy? If so...its the crankcase vent that's putting fumes back into the motor.
As for the oil in the valley of the motor...an oil galley plug o-ring could be the cuplrit. I've had a few of them go out and they can fill the valley fairly quickly. I would give them a look over first.
~Dave~
4cstr is offline
post #7 of 14 (permalink) Old 03-13-2011, 11:58 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Alright guys, Ill check this out. can we vent the CCV out of the intake?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #8 of 14 (permalink) Old 03-14-2011, 12:36 AM
4cstr's Avatar
Images: 35
yeah...you can. called the CCV mod. On the drivers side valve cover you will see where the breather tube comes off the cover and into the intake stream. Rotate the breather cap on the valve cover 180*, then attach some 3/4" heater hose. Route up and over the master cylinder, then down the firewall and alone the drivers side frame rail. But be forewarned...if the hose becomes blocked due to frozen steam/mist...it will pressurize your motor and may blow the dipstick out, blowing oil all over the motor. Trust me on this :
you just will need to replace the plastic part in the intake where the motor vented to. A small piece of 4" exhaust works great...and if its SS it adds a little bling to the motor.
~Dave~
4cstr is offline
post #9 of 14 (permalink) Old 03-14-2011, 03:49 AM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Ok, guys, Did some snooping and looks like my neighbor was able to put a few turns on the orange silicon boots from the intake to each head. I Think the next step we are going to do is degrease the top of the motor. (being very careful not to get electrical connection wet. Any pointers here) I both valve covers look like they have had oil residue building for some time. There is a puddle in the center of the valley but no obvious source. Is there a diagram to show the oil galley plug?
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #10 of 14 (permalink) Old 03-18-2011, 06:09 PM Thread Starter
ADMIN/MAFIA
neeltburn's Avatar
Since we tightened up the books on the intake going in to each head, it has not dripped on the ground, is there a CCV Filter in on the drivers side valve cover and it so who has the part #.
Next can we spray engine degreaser on it the top of the motor in the valley and hose it out? I know the GPR and other electronics are up there, is this same and if you have done it how did you go about doing it? On motors I have done in the past I just rinsed it off lightly and took compressed air and blew as much of the water I could off of it.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
OK fuel leak stopped now oil leak Stacked6600 1994-2003 7.3L Power Stroke 7 01-27-2011 04:37 AM
oil leak 375.0ford 5.9L Cummins (2003-2007.5) 5 07-24-2009 12:24 AM
oil leak MoBe88 2003-2007 6.0L Power Stroke 6 07-20-2009 12:36 PM
leak strokethisfordboy09 5.9L Cummins (2003-2007.5) 0 07-13-2009 12:17 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
