question about 7.3 up pipes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RussK, this thread has received 3 replies and been viewed 3089 times.
post #1 of 4 (permalink) Old 03-17-2011, 11:27 PM Thread Starter
RussK's Avatar
My up pipes are leaking the question I have is how much do they effect power.
And can they also affect the way it shifts? As in, staying in the lower gears longer.
(shifting at higher RPMs)
The computer looks at the map and exhaust pressure to determine when to shift and they will be off if boost is off as well.
My EBP under hard acceleration is 42.93 lbs
My MAP under hard acceleration is 31.03 lbs
Both seem low until 2000 RPMs and then it pulls hard just low power @ lower RPMs
01 7.3 SD automatic 4x4
Thanks for and advice you can give me.
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan bucketsí covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wifeís)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #2 of 4 (permalink) Old 03-18-2011, 09:18 PM
I could barely make 10psi with leaky uppipes (229,000 miles). Changed them to bellowed and now get 23 or so unloaded uphill.
Changing the boots this weekend and we'll see how it goes.
I've got a Stick, so no help on the tranny.
I am new, but isn;t MAP and boost similar?
pachary is offline
post #3 of 4 (permalink) Old 03-19-2011, 01:57 AM Thread Starter
RussK's Avatar
They are, I work on gassers 90% of the time, and it was also listed as map on my scanner so I just didnít think anything about it
My bad
Thanks for the info that seams to be the way mine is running.
How did yours run at higher rpms with the leaks ?
Singles club #164
american club # 9
Russell
RussK is offline
post #4 of 4 (permalink) Old 03-19-2011, 06:05 AM
Mine did not make much boost at top end. 10-12 MAX. My exhaust temps would get to 1200 really, really quick.
I would guess if you are getting high boost on hard accel, you are looking at something different than mine.
What is the EBP at other speeds/idle?
pachary is offline
6.4 up pipes SEABEE08FX4 Ford Parts wanted 0 09-15-2010 03:26 AM
y pipes ? hotshot4819 2003-2007 6.0L Power Stroke 3 04-14-2009 02:01 AM
DI up pipes wftree General Ford Truck and Excursion 11 02-11-2007 05:05 AM
Down Pipes Steve McQueen 1994-2003 7.3L Power Stroke 5 01-17-2007 06:31 PM
Down Pipes redneck_psd 2003-2007 6.0L Power Stroke 3 08-13-2006 02:36 AM
