2000 cruise control - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Greyhorse, this thread has received 4 replies and been viewed 1871 times.
post #1 of 5 (permalink) Old 03-18-2011, 12:17 AM Thread Starter
2000 cruise control
I have a 2000 F350 Diesel that the cruise has quit working on. I know it isn't the brake sensor on the master cylinder, replaced it for the second time. No fuses blown that I can find. Brake light switch seems to work correctly, speedo works correctly. No codes. Anyone have any other ideas?
1999 IH 4900, DT466E 250hp, MD3060
2000 F350
Greyhorse is offline
post #2 of 5 (permalink) Old 03-18-2011, 01:18 AM
RussK's Avatar
can you get ahold of a scanner, mine will tell me what my switches are doing
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan buckets’ covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wife’s)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #3 of 5 (permalink) Old 03-18-2011, 01:42 AM
cruise control
it may be the clock spring behind the steering wheel an easy way to tell is if your horn doesnt work and or maybe your air bag light is on that why mine didnt work anyway
Good luck
Russ_V is offline
post #4 of 5 (permalink) Old 03-18-2011, 02:36 AM Thread Starter
Russ_V
The horn works and no airbag light..... might only be the part that does the cruise.
RussK
The shop down the road from me might have a better scanner than the parts store I tried, I'll see if his scanner can tell if the switches are working or not. He might not charge me. Most of the other shops around here charge $75- $100 to hook it up for 5 minutes (1 hour of labor). BTW what kind of scanner do you have, I think I probably need to get one sooner or later for this truck.
Thanks
2000 F350
post #5 of 5 (permalink) Old 03-18-2011, 03:30 AM
RussK's Avatar
i got a snap-on solus/ OTC Pegisys
Singles club #164
american club # 9
Russell
RussK is offline
Cruise Control ICEMAN3005 6.2L Diesel Engine 2 07-09-2010 08:13 PM
cruise control budwagon1274 2003-2007 6.0L Power Stroke 1 07-31-2009 07:03 AM
Cruise Control Imbiggerthanyou 5.9L Cummins (1998.5-2002) 9 01-24-2009 03:01 PM
cruise control topflight250 1994-2003 7.3L Power Stroke 9 01-16-2009 12:09 AM
Cruise Control vs. MPG volwing 2008-2010 6.4L Power Stroke 4 02-24-2008 12:22 AM
