New Fuel System - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackcloud02, this thread has received 5 replies and been viewed 2247 times.
post #1 of 6 (permalink) Old 04-24-2011, 04:46 AM Thread Starter
blackcloud02's Avatar
Send a message via Yahoo to blackcloud02
Question New Fuel System
Looking for a fuel system for my truck. Im running a TSperformance 140hp chip. To me just seams like my injectors are starving for fuel on that setting. Any ideas.?
2002 7.3 4door 4x4 XLT Lariat. 6in Lift 38x15.5R20s, TS Performance with Tony Wildman Tunes, AEM Bruit Force Cold Air Intake, Boost Relief Valve, Wicked Wheel, Stage One Single Shot Injectors, Adrenaline HPOP, ATS Stage 2 Transmission And Torque Converter, MBRP 4" Turbo Back To A Single 7in Black Powder Coated Stack.
blackcloud02 is offline
post #2 of 6 (permalink) Old 04-24-2011, 06:01 AM
the injectors want more oil pressure with the chip in the 140 hp setting
EpSiloN is offline
post #3 of 6 (permalink) Old 04-24-2011, 06:16 AM Thread Starter
so a bigger HPOS should salve that issue?
post #4 of 6 (permalink) Old 04-24-2011, 10:06 PM
plainredtruck's Avatar
Images: 11
It probably will go farther toward boosting you performance than a fuel system will at this point.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #5 of 6 (permalink) Old 05-02-2011, 05:06 PM
The one and only
I would look into getting a reburn on that TS chip 1st.
The tunning on them arent the best. Yes you would have a weak HPOP but im going to guess that its just the tuning is junk.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #6 of 6 (permalink) Old 05-29-2011, 03:37 PM Thread Starter
have a freind with the same chip from a diff dealer. He is having the same issue on the 140 setting. gonna try the HPOP first see if the helps. thanks
Air dog fuel system squamishf350 2008-2010 6.4L Engine Tuner Forum 1 01-11-2011 05:06 AM
Fuel system olred07 2008-2010 6.4L Engine Tuner Forum 1 03-12-2010 04:05 PM
fuel system Orangepstroke 1994-2003 7.3L Power Stroke 6 05-08-2009 05:27 AM
Need help fuel system 97CumminsTurboDiesel 5.9L Cummins 12 Valve (1994-1998.5) 4 04-24-2009 02:45 PM
Fuel System powerstrokin94 1994-2003 7.3L Power Stroke 1 05-02-2007 04:30 PM
