whats a good chip for a 99.5? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by outlaw108, this thread has received 9 replies and been viewed 2649 times.
post #1 of 10 (permalink) Old 06-09-2011, 12:37 AM Thread Starter
I've got a 99.5 and I'm looking to chip her out I want one of them with a the digital gauges on the tranny and turbo temp. I'm looking to spend less the 600 and I also need a new injector anyone got some suggested websites or brands? I kinda like the edge attitude is that a good option? And is beabsdieselperformance.com a good site? Thanks for the help.
Oh and today my tranny slipped twice its got 200k on original fluid think the tranny is junk or would new fluid fix me up?
outlaw108 is offline
post #2 of 10 (permalink) Old 06-09-2011, 02:30 AM
F350-6's Avatar
I've never heard of beabsdieselperformance, and apparently neither has my computer. However if you're talking about beans, then yes, they are a great company to deal with. They can also sell you a chip for the 7.3 that is MUCH better than the Edge, Superchips, Banks, or any of the off the shelf stuff you can buy at any parts store. There are many other good tuners for the 7.3 out there as well. DP, TDP, Gearhead, just to name a few.
Flushing the tranny won't hurt, but if it's acting up then a chip may not help. The Edge is known to cause rough shifts so I'd stay away from that one. I'd suggest you make sure your tranny is in good shape first before buying a chip or tuner. Then get a real set of gauges to monitor Boost, Tranny temp and EGT. Add an auxillary transmission cooler and a shift kit or modified valve body, and then stick a good custom chip on there and enjoy.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 380,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350-6 is offline
post #3 of 10 (permalink) Old 06-09-2011, 02:34 AM
He meant beans, and yes they are good. If your trans is already slipping then adding more power will kill it.
Pat 2000 F250
5"exhaust with 6" tip, mac intake, foil delete and zoodad :ford
silverf250 is offline
post #4 of 10 (permalink) Old 06-09-2011, 03:11 AM
dzljon's Avatar
i liked the 6 pos ts chip had lots of options with it.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #5 of 10 (permalink) Old 06-09-2011, 03:23 AM Thread Starter
Sorry I meant beans. I'm trying to stay under $650 since that's all the money I've been able to save up so far and i just dropped number 2 injector and today it was really hot and during city driving when i left a light I got on it hard and it pegged so I let off and it pegged again. Which was why I liked the attitude cause it has the gauges built in and was only like 240. So what you'd suggest is flush tranny and new injector and see if it holds up before getting a chip then?
post #6 of 10 (permalink) Old 06-09-2011, 03:27 AM Thread Starter
Well it wasn't slipping yesterday when I decided I wanted to chip it haha.
Is the valve body off strictly diesel a good choice if I happen to decide to beef her up some then chip down the road?
post #7 of 10 (permalink) Old 06-10-2011, 01:12 AM
F350-6's Avatar
I would. If you add more power to a weak tranny, then you will need a new one soon. If money's tight, you don't want to be buying a transmission.
Yes, the JW valve body Dennis sells is top notch. I believe Beans sells the BTS valve body. Either one will work since those are 2 of the premier bullet proof tranny builders.
Chris
F350-6 is offline
post #8 of 10 (permalink) Old 06-10-2011, 11:40 AM Thread Starter
Alright I ordered injectors this morning and got the stuff to flush the tranny. Would I have to pull the tranny to put the new valve body in? I know on my chevy I couldn't figure the balls out without dropping the tranny so I could turn it over lol. Any idea where I can get a better cooler for the tranny? This truck us used for towing a lot so I wanna make sure its gonna hold up once I chip it
post #9 of 10 (permalink) Old 06-10-2011, 12:39 PM Thread Starter
Sorry meant *any ideas where I can get a tranny cooler other then beans them ones are costy*
post #10 of 10 (permalink) Old 06-11-2011, 03:14 AM
F350-6's Avatar
Changing the valve body is easy. Drop the pan and it's a simple unbolt the old and bolt in the new. The check balls are above a separator plate. As long as you only remove one valve body when you change it, you have nothing to worry about besides the transmission fluid dripping on you.
You can keep your eye out for a 6.0 diesel transmission cooler. Sometimes you can find a deal on those on craigslist, ebay, or a wrecking yard and use it. Just be sure to flush any used cooler and install a magnefine filter between the cooler and transmission when you do the install.
Chris
F350-6 is offline
The Following User Says Thank You to F350-6 For this addition to TDG:
outlaw108 (06-15-2011)
whats a good price for a used 6.4L stacks 2008-2010 6.4L Power Stroke 10 02-11-2009 10:21 PM
whats some good performance mods? Hotrodx199 24 Valve Performance 5 04-20-2008 11:32 PM
Whats this Chip? cummins0797 1994-2003 7.3L Chips & Tuners Forum 10 10-31-2007 05:21 PM
Whats a good clutch? sstockton 1994-2003 7.3L Power Stroke 9 03-13-2007 10:52 PM
Whats a Good Lift Kit wetland_farms 2003-2007 6.0L Power Stroke 16 03-23-2006 10:10 PM
