HELP!!7.3 WON'T START - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by j1586, this thread has received 5 replies and been viewed 7240 times.
post #1 of 6 (permalink) Old 06-12-2011, 02:04 PM Thread Starter
have a 2002 f350 that I am chasing a problem. new icp, new ipr, new HPOP,New fuel pump with prefilter, fresh batts and fuel in the bowl and no start.
ran AE scan tool before HPOP replaced.
1. Injector buzz test passed with no problems.
2. When we tried to run the cylinder contribution test, the engine died as soon as the first injector was dropped out by the test - I don't think it related to that injector.the RPM dropped too much. We repeated the test and the same thing happened again.
3. I have a DP tuner, and the engine would only stay running if the tuner was on the high idle program. If you took it back to stock, the engine died immediately.
The IPR Duty Cycle is at about 14% with the engine off, jumps up to about 65% while cranking, and then came back down to about 14% once the engine is running. ICP was around 650-700 psig.
I have replaced the fuel filter, injector cups & o-rings.
Before hpop replacement it would start with small amount of starting fluid but will not stay running at low speed/idle. after the replacement i finally got it started and it even would idle down. it died while idling and hasn't started since.
I am in Ct and have to be in TX in 2 weeks! any help would be appreciated.
j1586 is offline
post #2 of 6 (permalink) Old 06-12-2011, 02:17 PM
Sounds like an Injector Pump issue. Or maybe a sensor has gone bad. Cam position sensor maybe? I'm sure someone will be in here shortly that has a better idea of what your issue is. Good luck!
SCRecovery is offline
post #3 of 6 (permalink) Old 06-12-2011, 02:25 PM Thread Starter
CPS replaced earlier and even swaped it for a spare-no change
oil changed prior to hpop replacement
HPOP replaced on monday. truck has been cycled 20-30 times since. even ran for a 2-3 min period before dying.
no oil in fuel bowl
I don't have a scanner here. Greg in Ledyard hooked it up when my truck was running poorly but still runnning.
truck will not start at this point even on ether
j1586 is offline
post #4 of 6 (permalink) Old 06-12-2011, 02:59 PM
That's wierd. I am not sure what could make it not start on ether. I would be tempted to just take it to a shop. That may be cheaper in the long run.....and faster too.
post #5 of 6 (permalink) Old 06-13-2011, 03:42 AM
plainredtruck's Avatar
Images: 11
If you can get a replacement IDM, try that.
Injector Driver Module.
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #6 of 6 (permalink) Old 06-15-2011, 07:39 PM
Since its got a new HPOP I'm sure you did but I'd make sure the HPOP has oil in it and that the pan is full. I've had my truck do the same thing because of low oil... also I'd make sure your pushing fuel by unhooking the fuel line from the pump under the hood if your not moving fuel try taking the line off the back of the pump and take some locus injector cleaner and squeeze the injector cleaner backwards through the line sometimes if them screens are plugged that will make it run again for a little bit. Can also check and make sure you high pressure oil lines going to the heads aren't leaking. Just some ideas good luck
outlaw108 is offline
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 11:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
