Fuel Bowl Delete - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackcloud02, this thread has received 10 replies and been viewed 7490 times.
post #1 of 11 (permalink) Old 07-17-2011, 12:30 AM Thread Starter
blackcloud02's Avatar
Send a message via Yahoo to blackcloud02
Question Fuel Bowl Delete
I'm highly considering doing a fuel bowl delete kit on my 02 7.3... Has anyone dones this? And is it realy worth doing it?
2002 7.3 4door 4x4 XLT Lariat. 6in Lift 38x15.5R20s, TS Performance with Tony Wildman Tunes, AEM Bruit Force Cold Air Intake, Boost Relief Valve, Wicked Wheel, Stage One Single Shot Injectors, Adrenaline HPOP, ATS Stage 2 Transmission And Torque Converter, MBRP 4" Turbo Back To A Single 7in Black Powder Coated Stack.
blackcloud02 is offline
post #2 of 11 (permalink) Old 07-17-2011, 05:35 PM
Super Moderator
John_G's Avatar
Why?
I vote for LIBERTY!
John_G is offline
post #3 of 11 (permalink) Old 07-17-2011, 09:24 PM Thread Starter
That kinda what I'm asking. I'm looking at running either a fast fuel system or air dog system on my truck. Do I really need my fuel bowl? Or is deleting it a better way to go.?
post #4 of 11 (permalink) Old 07-18-2011, 01:47 PM
Super Moderator
John_G's Avatar
I am not familiar with the specifics of either aftermarket system, they simply are not needed for even significant power gains. The factory fuel system, filtration specifically, is very good and the question is then what would be used as a filter? I believe there are aftermarket systems, maybe the ones you arae thinking of, that have a remote mounted filter.
My advice is to keep the factory system unless you cannot keep fuel delivery pressure in spec under load. If that happens, either replace the in-tank pump with a higher volume unit or ditch the entire OEM system for something else.
I vote for LIBERTY!
John_G is offline
post #5 of 11 (permalink) Old 07-18-2011, 06:24 PM
rollingcoal69's Avatar
Useing a Airdog or Fass system will replace the entire factory system. if you go one of those then yes you can delete the factory fuel bowl.
Scott
99 F250 SC LB 4X4 Build Date 4/98 Canada Truck
170k on the clock
Power everything
Glow Shift gauges
TS 6 pos
DIY Intake
4" from the turbo to a 5" single stack with rain cap
Schaeffer Oil
Kenwood DVD Player
12" sub and Pioneer 800w amp
New tranny @ 105k
rollingcoal69 is offline
post #6 of 11 (permalink) Old 07-19-2011, 04:06 AM
I deleted my fuel bowl several months ago. I already had a regulated return kit from DI on my truck. Just picked up some Parker hose, fittings and connections, and a couple of spin on filters and water separators with bases. Then I ripped out the original fuel line, replaced it with the new fuel line, relocated the fuel pump, and placed the water separator in front of the pump, and the filter behind the pump. No more fuel bowl, and it all tied in nicely with the regulated return.
I did this because the original fuel bowl cracked and leaked. The replacement was showing the same stress cracks in the exact same spot, and I just didn't trust the stock bowl setup anymore after that. The stock bowl functions fine, but it's cheaply made. Plus the spin on filters are just easier to replace under the truck. It also cleaned up the engine valley a bit.
Pocket is offline
post #7 of 11 (permalink) Old 07-26-2011, 03:31 AM Thread Starter
Rollingcoal- Thanks for the post. I've ben really looking at the airdog systems.
Pocket-Thanks for the info on how u did yours. I'll deff keep your post in mind and may use some of your ideas.
post #8 of 11 (permalink) Old 07-27-2011, 12:39 AM
no problem. let us know how it goes.
Scott
170k on the clock
Power everything
Glow Shift gauges
TS 6 pos
DIY Intake
Schaeffer Oil
Kenwood DVD Player
New tranny @ 105k
post #9 of 11 (permalink) Old 07-27-2011, 05:31 AM Thread Starter
Will do
post #10 of 11 (permalink) Old 07-31-2011, 03:13 AM
It really wasn't that hard to do. The main thing was getting the hose and the -6AN fittings that matched up, and making sure I had enough of everything. Beyond that, I think the hardest part was removing the old fuel line. Maybe in second place was drilling the frame to mount the filter, water separator, and relocating the fuel pump. After that, it was a breeze. Seriously, it was a far easier job than I thought it would be.
On a side benefit.... I did find out that deleting the fuel bowl allowed me to still start and idle my truck when the fuel is completely gelled in negative temps. Something I was never able to accomplish with the stock fuel bowl in place.
Pocket is offline
Fuel Bowl Mod ? john 1994-2003 7.3L Power Stroke 9 05-20-2009 05:06 PM
Glacier fuel Bowl delete Robts Whats Been Sold 0 04-20-2009 12:43 AM
fuel bowl ? dieselman723 1994-2003 7.3L Power Stroke 1 01-19-2008 04:58 AM
Fuel Bowl Delete Question 6_Myles 1994-2003 7.3L Power Stroke 6 12-25-2007 05:12 AM
Prefilter and fuel bowl delete 6_Myles 1994-2003 7.3L Power Stroke 9 11-26-2007 01:44 PM
