Front Brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Russ_V, this thread has received 3 replies and been viewed 1886 times.
post #1 of 4 (permalink) Old 09-07-2011, 01:19 PM Thread Starter
Front Brakes
I'm having a little brake problem front pass. side brake is sticking pulled guide pins cleaned an lubed anything else i can try before i start throwing money at it. thanks.
Russ_V is offline
post #2 of 4 (permalink) Old 09-07-2011, 02:20 PM
4cstr's Avatar
Images: 35
I know this sounds like a silly question...but when was the last time you changed the brake fluid?
Here is a link to DIY brake fuild change. DIY brake fluid change
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
Russ_V (09-08-2011)
post #3 of 4 (permalink) Old 09-07-2011, 03:53 PM Thread Starter
front brakes
ahhh never been changed i don't think.
Russ_V is offline
post #4 of 4 (permalink) Old 09-08-2011, 01:43 AM Thread Starter
solved
Had a piston stuck but did change the fluid out while i was there thanks for the help.
Russ_V is offline
Front Brakes socofn 5.9L Cummins (2003-2007.5) 1 05-08-2010 09:42 PM
PLEASE HELP front brakes removal just visiting 1994-2003 7.3L Power Stroke 12 02-23-2010 03:01 AM
Front Brakes boobin 2003-2007 6.0L Power Stroke 5 10-05-2009 02:08 AM
Front Brakes 2wd = Ooch $$$ NotMine 2003-2007 6.0L Power Stroke 7 08-25-2009 01:21 AM
need front brakes powerstrokeit Supporting Vendors Forum 1 11-06-2007 03:13 AM
