Cold start no throttle response - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dougwdavis, this thread has received 3 replies and been viewed 2768 times.
post #1 of 4 (permalink) Old 09-26-2011, 04:05 PM Thread Starter
I have a 2002 Ford F350 with a 7.3 powerstroke with 180k on it i ran great in the summer when i bought it now it is getting in the 40s it was haveing trouble starting and when it did i had no throttle response until it warmed up for 20 minutes. i have replaced my fuel and air filter, changed the oil, replaced GPR, Replaced glow plugs with new dual coil plugs. now it will start although it will have no throttle response until the temp guage is above the lower limit on the guage which takes like 20 minutes or me to sit there and rev it up the little that it will go for a while. although if i plug the truck in i do not have a problem. I believe after a little research that it could be my EBPV is sticking when closeing. is there anyway to check it without takeing the turbo off? after the truck is ran in the morning it is fine all day long. thank you for any help i can get on this.
dougwdavis is offline
post #2 of 4 (permalink) Old 09-26-2011, 07:48 PM
Diesel Dave 04's Avatar
If you do a compression test and it is good then I would say it needs injectors.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #3 of 4 (permalink) Old 09-26-2011, 10:56 PM Thread Starter
I am wondering how could it be the injectors if after it warms up it is fine plenty of power and no problems when you start it at all it is just the initial cold start. After replaceing the glow plugs it starts fine but it has little to no throttle response untill the temp guage comes up.
post #4 of 4 (permalink) Old 09-26-2011, 11:33 PM
Because the inturnals (popit and barrel) are scorred and sticking untill they expand.
2000 T444E,White smoke, poor throttle response when engine cold Bkttruck Medium and Heavy Duty 12 03-24-2011 02:37 PM
No Throttle Response Upon Cold Start unforgiven76 1994-2003 7.3L Power Stroke 9 12-26-2010 10:28 PM
no throttle response spanky 5.9L Cummins (1998.5-2002) 5 09-30-2007 07:20 PM
throttle response govols 5.9L Cummins (2003-2007.5) 0 05-05-2007 10:43 PM
Slow throttle response when cold, lots of blue/white smoke at wot anytime ferrel0 1994-2003 7.3L Power Stroke 1 03-30-2007 10:16 PM
