Looking to convert 2wd dually to 4wd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mtnsammy, this thread has received 3 replies and been viewed 2202 times.
View Poll Results: Should I leave the 6spd dually 2wd or convert it to 4wd?
Leave it alone 1 16.67%
Convert to 4WD 3 50.00%
Sell 2wd and buy a 4wd already done. 3 50.00%
Duallies should be left 2wd. 1 16.67%
Multiple Choice Poll. Voters: 6. This poll is closed
post #1 of 4 (permalink) Old 10-02-2011, 06:50 PM Thread Starter
I have a 1999 DRW 6 spd that I am looking to convert to 4wd. I know it can be done but what I am asking for is suggestions others found when doing theirs or PROBLEMS they encountered while doing their conversion. I figure it will be a week long project but I will be retired in January and have a lot of time on my hands then.
Parts I know I will need;
new tailshaft/ output shaft
transfercase
driveshafts front and rear
shifters
floor plate
wire harness from donor truck
front axle
lots of dirt and mud to test drive on.
I am assuming the frame has the bolt up predrilled and most everything else is set up for either 2wd or 4wd. I occasionally see the dash light for low range light up anyways so it should be good???
Naysayers stay off please. I want to hear from those that have done it already. I figure if I can fab a diesel into a Samurai I can convert a 2wd into 4wd just fine.
Thanks ahead and if anyone needs extra hunters let me know for 2012. My truck and I will be ready.
mtnsammy is offline
post #2 of 4 (permalink) Old 10-11-2011, 09:37 PM Thread Starter
WOW No one?? I would think this has been done several times. Plenty of time till I start.
My friend has a shop and can do the trans rebuild with the 4X4 conversion for an extra $300. The transfer case he has is already rebuilt. After that I guess it is blocks for the rear with brakeline extenders and an axle from the yard prob Dana 70 straight from another SD truck. Still not sure on floor boards. I will find out when I pull the axle out of the yard truck.
mtnsammy is offline
post #3 of 4 (permalink) Old 10-14-2011, 12:34 PM
In order to change the output shaft you will have to do a total tranny dissisembly. should do a tranny rebuild at the same time if thats what you are going to do. Good Luck
jcatchem is offline
post #4 of 4 (permalink) Old 10-14-2011, 12:41 PM
I forgot to let you know that not all the holes are pre-drilled and the pockets in the front shackles need the bottom web of the frame cut out and indented. Its not hard, just wanted to inform you. I did it very successfully and would do it again.
jcatchem is offline
convert SRW to DRW? Lurkin 2008-2010 6.4L Power Stroke 12 06-10-2009 01:42 AM
if i was to convert... 97UTPSD The Parking Lot 6 05-05-2009 07:26 PM
convert dually to single wheel ash_flat_diesel 2003-2007 6.0L Power Stroke 0 03-07-2008 12:06 AM
convert xl ..to xlt?? blackcloudCTD95 1994-2003 7.3L Power Stroke 14 07-13-2006 03:52 AM
Convert.... Deezle1 2003-2007 6.0L Power Stroke 14 11-16-2005 08:40 PM
