Dual mass flywheel? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 3 replies and been viewed 3099 times.
post #1 of 4 (permalink) Old 01-04-2012, 11:42 PM Thread Starter
cumminsdiesel's Avatar
Dual mass flywheel?
Just wondering if any one can tell me if this is a dual mass flywheel or not? If you need more pictures I can take some more. Truck is a 97 f250. Thanks.
Name:	heathers camera 2011 485.JPG
ID:	29766   Click image for larger version
Name:	heathers camera 2011 497.JPG
cumminsdiesel is offline
post #2 of 4 (permalink) Old 01-05-2012, 04:33 AM
strokinit's Avatar
About the only way you're gonna know is to pull it out...Or see if you can find the factory Ford stamping on the clutch cover...If you know this is the original clutch in this truck, then yes, it is a dual-mass flywheel...
strokinit is offline
post #3 of 4 (permalink) Old 01-05-2012, 07:00 PM
Diesel Dave 04's Avatar
Looks like a dual mass to me If you grab the clutch side can you move it without the flywheel moving or say without the ring gear side moving?
If so then yep it is a dual mass and the stock flywheel in a 97 diesel was a dual mass.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #4 of 4 (permalink) Old 01-06-2012, 02:15 PM
Yes that is the dual mass.
Peter
sb clutch is offline
Gear noise with Single Mass Flywheel StrokerDude 7.3L and 6.9 IDI (Pre 1994) 3 02-08-2011 12:44 AM
Does anyone know if the 7.3 dual mass flywheel can be "locked out"? flyingcoscott 1994-2003 7.3L Power Stroke 0 01-10-2011 01:48 PM
Anyone locked out a dual mass flywheel before? dieselboy740 7.3L and 6.9 IDI (Pre 1994) 12 01-10-2011 01:27 PM
Ford IDI dual mass flywheel and clutch 6Gears Ford Parts 0 11-15-2009 02:19 PM
Single Mass VS. Dual MAss TSGS69400 1994-2003 7.3L Power Stroke 8 01-10-2008 10:11 PM
