7.3 4R100 Issues - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Pcupo12, this thread has received 6 replies and been viewed 2355 times.
post #1 of 7 (permalink) Old 01-09-2012, 04:10 PM Thread Starter
7.3 4R100 Issues
Titles says it. I plow/tow a trailer with my truck. 99 F250 SD. Its on its third tranny. I want this one to last. So far I put a Temp gauge in the pan and a big 6.0 cooler up front. It was still running over 200, so I mounted a 16inch diameter pusher fan infront of the AC condenser (wont fit between Ac condenser and trans cooler). I hooked it up to a toggle switch so I can just let it run. What else can I do to keep the tranny cool, the truck is 100$ stock, no chips or anything.
Pcupo12 is offline
post #2 of 7 (permalink) Old 01-10-2012, 01:45 AM
Diesel Dave 04's Avatar
maybe the cooler bypass is open i would call bts and ask brian what to do.
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #3 of 7 (permalink) Old 01-10-2012, 03:16 PM Thread Starter
what is the cooler bypass? The cooler is not connected to the radiator anymore. The lines go from the trans right to the cooler, then back to the trans.
Pcupo12 is offline
post #4 of 7 (permalink) Old 01-10-2012, 04:09 PM
on a 4 R 100 there is a line that runs from the front cooler line port back to the rear cooler line port that is a bypass.
post #5 of 7 (permalink) Old 01-10-2012, 04:44 PM Thread Starter
Thats the passenger side trans line right? I just bought the BD block off spacer kits. Do they both go on the passenger side line? One spacer in the front and one in the rear? Also, do you REMOVE the "check valve" or just put the spacer over it to plug the holes? Thanks.
Im guessing you just take the banjo bolt off, slip the spacer over it and put it back?
Pcupo12 is offline
post #6 of 7 (permalink) Old 01-11-2012, 12:35 AM
sorry i dont know anything about the BD kit.
post #7 of 7 (permalink) Old 01-12-2012, 01:53 PM Thread Starter
Im taking the truck to Ford. Having them flush the trans system. Im going to have them see if everything is working right. Including the bypass valve. If not, Im going to replace it first, see how it works. If I still have heat, ill try blocking it off.
Pcupo12 is offline
4R100 Issues. Pcupo12 1994-2003 7.3L Power Stroke 13 12-19-2010 04:53 AM
4r100 in obs??? shawnrans 1994-2003 7.3L Power Stroke 9 10-02-2009 12:48 AM
New to the 4r100 R33615 1994-2003 7.3L Power Stroke 3 08-22-2009 04:52 AM
4r100 help ford7.3sd 1994-2003 7.3L Power Stroke 14 02-29-2008 01:56 AM
4r100 Bluemonster 1994-2003 7.3L Power Stroke 5 04-17-2006 05:00 PM
