Release bearing slop! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 0 replies and been viewed 1565 times.
post #1 of 1 (permalink) Old 03-25-2012, 07:34 AM Thread Starter
cumminsdiesel's Avatar
Im putting in my new Luk clutch kit in my 97 PSD with a zf5 and came across something that im not sure is normall. The new release bearing when put on the front bearing retainer(nose cone) of the transmission has some slop in it. Is this normall or is it supposed to be tight? Thanks.
cumminsdiesel is offline
Steering gear box slop legend10 Medium and Heavy Duty 6 09-04-2010 06:35 PM
Proper fix for spring shackle slop legend10 Medium and Heavy Duty 8 06-07-2010 01:30 AM
Connecting Rod Release BogginF350 Supporting Vendors Forum 4 06-03-2010 08:14 PM
New Product Release SpartanDieselTech 2008-2010 6.4L Engine Tuner Forum 95 08-30-2009 04:38 PM
Ball Bearing vs. thrust bearing hersh211 1994-2003 7.3L Power Stroke 8 07-18-2007 05:36 AM
