Brake Part Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BillsFan, this thread has received 5 replies and been viewed 2134 times.
post #1 of 6 (permalink) Old 04-07-2012, 01:30 AM Thread Starter
BillsFan's Avatar
Brake Part Question
What is this piece called that holds the pads under the caliper? One of my pins is frozen and I cant get it to budge. Any idea what it costs? Im guessing its a dealer only part or maybe a scrapyard...
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #2 of 6 (permalink) Old 04-07-2012, 02:36 AM Thread Starter
BillsFan's Avatar
Ok, looking at some aftermarket sites it looks like this comes with the caliper and isnt an individual part.
Ridin' Dirty #64
BillsFan is offline
post #3 of 6 (permalink) Old 04-07-2012, 02:21 PM
ADMIN/MAFIA
neeltburn's Avatar
You have the caliper braked there and the pins are called break slides. The metal clips will come with you new pads.
All of the items should be avalible at your local parts store such as O'Rieleys or Autozone. Napa would also have these things.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
BillsFan (04-08-2012)
post #4 of 6 (permalink) Old 04-07-2012, 02:26 PM
ADMIN/MAFIA
neeltburn's Avatar
Brake slide or guide pin from Auto Zone Click here
Front Caliper Bracket
Rear Brake Caliper brackets
Be sure to check with them since you have a SRW that these are correct but that should be what you need.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
post #5 of 6 (permalink) Old 04-07-2012, 07:01 PM
That is the Caliper mount, with the price of the caliper assembly so cheap now, I do not do brake jobs without changing the caliper and the mount. Every time I do, the slide pins seized and then you risk loosing the inner brake pad and destroying the disc.
One thing you want to remember is, never force the fluid back into the ABS assembly. I clamp the hose or remove it, then collapse the caliper. or open the bleeder if you are planing on reusing it.
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
post #6 of 6 (permalink) Old 04-08-2012, 01:24 AM Thread Starter
BillsFan's Avatar
Got the replacement at Autozone, plus some new pins and some anti seize. Shes braking like a champ again!
Ridin' Dirty #64
BillsFan is offline
Part Number Question 04lariatfx4crewcab 2003-2007 6.0L Power Stroke 1 11-13-2010 06:48 AM
Part # Question??????? CrashFireRescue 1994-2003 7.3L Power Stroke 0 02-23-2008 11:32 PM
Question about exhaust part? SouthTexasDiese 2008-2010 6.4L Power Stroke 3 08-02-2007 04:15 AM
Easy question for lift guru's part 2 nummit General Ford Truck and Excursion 2 02-21-2006 01:50 AM
Part Number Question... DarkShadow06 2003-2007 6.0L Power Stroke 5 11-07-2005 10:10 PM
