99 F350 CEL on runming rough - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jmbstudios, this thread has received 2 replies and been viewed 1855 times.
post #1 of 3 (permalink) Old 07-04-2012, 05:27 AM Thread Starter
Member in Learning!
We are camping near Imperial Beach, Ca and my wife took my truck to the store. On her way back it started running really bad, like it was running out of fuel and the check engine light came on. The way she described it sounds like the rpms were going from 800 to 200 for about 45 seconds then got better but was still rough and that's how it is now.
Im stressing because we leave to go home on friday and I have a trailer to haul.
With tomorrow being 4th of july I wont get it looked at til Thursday.
Do any of the scanners that.Autozone sells work for this truck? Maybe I can get a code that will help with the diagnostic.
Anyone experience this?
'99 F350 XLT, 7.3 PSD Crew Cab, LB, 4x2, Auto. DIY Intake.
Just learnin as I go!
jmbstudios is offline
post #2 of 3 (permalink) Old 07-04-2012, 11:08 PM
bpogue's Avatar
It is unlikely you can find a scanner at Auto Zone that will read diesel DTC. First, I assume it is not low on fuel. Check the fuel filter to see that the bowl is full of fuel. Check the oil level. Does it now act up constantly, or intermittently? What are the other gauges doing? Does the tach seem to read properly? What about the oil pressure gauge. Voltage?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 3 (permalink) Old 07-05-2012, 10:43 PM Thread Starter
Member in Learning!
It is full of fuel. Everything on the instrument panel functions as normal. I have no loss of speed, And torque seems to be fine.
Started it up today and.everything was fine. Then when I accelerated the.light came.back on and it was rough again. Not to rough. kind of like it has a small miss in it.
Went to a fuel up right when I stopped it smoothed out, light off. Then left, light on rough again.
2007 F350 6.0L runs rough looses power and dies Dual350 2003-2007 6.0L Power Stroke 7 03-06-2012 02:44 AM
2003 7.3 Liter F350 running rough (missing) rexpendergraft 1994-2003 7.3L Power Stroke 11 10-21-2010 02:54 AM
rough DodgeThis 5.9L Cummins 12 Valve (1994-1998.5) 5 02-25-2009 09:34 AM
03 F-250 Rough Idling silvervic99stang 2003-2007 6.0 Tuner Forum 11 03-07-2007 10:11 AM
04 f350 pulling a 04 f350 PSTROKER 2003-2007 6.0L Power Stroke 22 06-27-2006 04:32 PM
