Vibration/Growl @ highway speeds worse underload - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aldo_45030, this thread has received 5 replies and been viewed 3463 times.
post #1 of 6 (permalink) Old 07-10-2012, 01:47 PM Thread Starter
Been searching for the source of this noise,both Hubs replaced last year, tires rotated, new pads and rotors.
Sound or vibration is generally felt at highway speeds more prevalent under load, steering does not effect it,bumps no effect,consistent oscillation no matter in or out of gear and motor on or off. Looked for loose things and rubbing of things and found nothing.
Thinking front axle possibly?
2003 F350 CC SRW 4X4, 4" banks turbo back, 4 pos dp tunes, afe2 intake, leveled, gauges
aldo_45030 is offline
post #2 of 6 (permalink) Old 07-10-2012, 02:33 PM
BillsFan's Avatar
Have you checked the carrier bearing?
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #3 of 6 (permalink) Old 07-10-2012, 02:47 PM Thread Starter
I have not but when the tranny was rebuilt 3 weeks ago they indicated there were no problems.
Please expand on the proper way to check it and it seems the sound is more from the firewall bell housing area not behind the seat.
post #4 of 6 (permalink) Old 07-10-2012, 04:28 PM
BillsFan's Avatar
Start by checking it visually. Climb under there and see if anything looks worn and see if there is play where there shouldn't be.
Ridin' Dirty #64
BillsFan is offline
post #5 of 6 (permalink) Old 07-10-2012, 04:38 PM
BillsFan's Avatar
Does it sound like this?
http://www.youtube.com/watch?v=siH5rBI6DeE
Or this?
http://www.youtube.com/watch?v=GtJYQg_E1cY
Ridin' Dirty #64
BillsFan is offline
post #6 of 6 (permalink) Old 07-10-2012, 06:52 PM Thread Starter
nope the sound oscillates off and on sounds in the past i have heard similar sound from a bad rear wheel bearing on a front wheel drive car. You can feel it in the floor and not the steering.
I recall bad u joints would clunk the carrier bearing is cheap maybe i will just replace it and check fluid level in front diff which does nto appear to leak.
84 6.2L light blue smoke at highway speeds calebdugger1991 6.2L Diesel Engine 3 01-06-2011 12:39 AM
Better handling at highway speeds??? Sandman12 2003-2007 6.0L Power Stroke 9 11-03-2009 01:20 AM
smoke 5-6 highway speeds jlake 6.7L Cummins (2007.5-2011) 1 10-17-2009 01:44 PM
Engine growl at highway speeds w slight vibration JT61122 1994-2003 7.3L Power Stroke 3 05-02-2009 04:24 PM
Surge at highway speeds imported_KJR0360 2003-2007 6.0L Power Stroke 0 08-16-2006 11:14 AM
