7.3 bad skip - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bandit00, this thread has received 2 replies and been viewed 1976 times.
post #1 of 3 (permalink) Old 10-31-2012, 10:26 PM Thread Starter
7.3 bad skip
Engine only firing on right head. Left head is dead you can hold manifold. It's in a 12/95 e-350. Does this engine have injector modules?
Bandit00 is offline
post #2 of 3 (permalink) Old 10-31-2012, 10:59 PM
bpogue's Avatar
It could be an IDM problem. The most common problem with these is the wiring harness between the IDM and the injectors. It is called the UVC wiring (under valve cover). The wiring connector is a three piece connector, with the middle portion being part of the valve cover gasket. The inner connector tends to come apart. Ford makes a wedge kit to keep this from happening. Start by wiggling the connector while running. Sometimes you can get to work some this way. If so, then you know what you need to do.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 3 (permalink) Old 11-01-2012, 12:51 AM
There's an upgrade "bailing wire clip" style UVCH that is recommended if not already replaced, 4 required:
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
I would find it surprising if BOTH harnesses are cooked though, perhaps it is the IDM.
EDIT: another new thread on the same subject here:
https://www.thedieselgarage.com/forum...d.php?t=116611
'94.5, 5spd, 202k miles, Baby Swamps & Swamps tunes, Swamps IDM, Adrenaline HPOP & late IPR, IH Waterpump, S&B AF, 3" DP & 4" Magnaflow exhaust, gutted EBPV, Beans fuel, 6.0L Intercooler & Banks pipes, CCV Mod, ZF5 S547 & SB OFE, 3.55's & Truetrac diff, rear discs, Bilstiens, Redhead SB & Borgeson intermediate, A proud Texan 2WD XL
preith is offline
3406C skip OldHoods#1 Medium and Heavy Duty 8 02-06-2011 06:31 PM
Skip in engine under load! bluesmanmike5 Medium and Heavy Duty 8 08-26-2010 05:07 PM
'00 cold skip johndear720 1994-2003 7.3L Power Stroke 9 02-04-2009 05:14 AM
skip/idle funny powerstrokin94 1994-2003 7.3L Power Stroke 3 11-27-2007 03:21 PM
Cold skip help imported_johndear720 1994-2003 7.3L Power Stroke 3 10-21-2007 05:24 AM
