95 F350 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stacked6600, this thread has received 2 replies and been viewed 1837 times.
post #1 of 3 (permalink) Old 11-09-2012, 04:10 AM Thread Starter
SRW Cartell #27
Stacked6600's Avatar
95 F350
I have a 1995 F350 dually just picked it up ... good oil and all factory nothing but straight pipe. I am getting 7-8 MPG. OUCH> anyone know what i can check to help the fuel milage... Their is no fuel leaks. I have checked and i think the map sensor is on the fritz so replaced it and still CRAPY milage... what else can i check? also has 230000 miles on it.
1999.5 F250 4x4 super cab 7.3L With edge attituede.
Converter lockup mod and EBPV exaust brake mod.
Air Hog cold air intake. Muffler delete, 35s on centerlines.
New F650 dash upgrade..
1995 F250 Single cab long bed 2wd.
2001 LB7 2500HD SOLD
AEM Brute Force intake, 5 1/2 stack exaust, Diablo Sport Predator Programmer. PPE boost valve, Autolite gauges. Built Allison (Alto steels, Red eagle clutches, Transgo shift kit, transgo lockup valve, and Personal Mods : ) edelbrock 1792 lift pump.
Singles Club Member #27
Stacked6600 is offline
post #2 of 3 (permalink) Old 11-11-2012, 02:07 AM
Diesel Dave 04's Avatar
injector orings
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
The Following User Says Thank You to Diesel Dave 04 For this addition to TDG:
Stacked6600 (11-13-2012)
post #3 of 3 (permalink) Old 11-13-2012, 08:19 PM Thread Starter
SRW Cartell #27
Originally Posted by Diesel Dave 04 View Post
injector orings
if it was Orings would i leak fuel somewhere or just low compression or what? It doesnt smoke runs clean .. Oil looks good. Can you explain how the orings would make bad fuel milage? Thanks in advance.. I have never had this type of problem
1996 f350 7.5l swap with my 1996 f350 7.3l whiskey650 1994-2003 7.3L Power Stroke 0 08-20-2010 06:38 AM
D60 from 86 F350 Groundhawg Ford Parts 0 07-29-2009 07:30 PM
How about a 96 F350 4WD? John143 1994-2003 7.3L Power Stroke 3 04-19-2008 08:29 PM
New f350 KR........ fireplug45 2008-2010 6.4L Power Stroke 11 08-29-2007 06:29 AM
04 f350 pulling a 04 f350 PSTROKER 2003-2007 6.0L Power Stroke 22 06-27-2006 05:32 PM
