10.25 Rear Axle-Install New Limited Slip Clutches? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Birken Vogt, this thread has received 4 replies and been viewed 3219 times.
post #1 of 5 (permalink) Old 11-11-2012, 02:46 AM Thread Starter
Fire App. Mech.
I have a 1997 F-250 (old style) and the limited slip rear is about shot with 230,000 miles on it. It used to work OK but now it's pretty much open. It might have been from when I had to take a fairly long drive home with a slightly mismatched spare, I don't know.
Anyway I have heard it is not too bad to roll new clutches into these things without taking the whole thing apart. Anybody have any tips?
Birken Vogt is offline
post #2 of 5 (permalink) Old 11-11-2012, 03:31 AM
Aimless Wanderer
Pull the axle shafts, remove the rear cover, remove the differential center pin to remove the differential side gears, (spider gears) and the clutches pull right out. Reassemble but I always like to pre oil the clutch plates upon reassembly. Expect the limited slip action to be a bit aggressive for a few days after installation till the clutches seat in. Use the limited slip additive in the gear oil.
This is assuming your truck has full floating axles. Some F250's did not have these and the axles were retained by "C" clips on the inner axle shafts which are easy to remove once the differential center pin is removed, and the axles pushed in towards to the center of the differential.
Backslap is offline
post #3 of 5 (permalink) Old 11-18-2012, 10:26 PM
TDG SinglesClub Member#90
Where is the best place to get the clutches?
1996 Ford F350, 7.3 PSD, crew cab, 8ft(Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Nitto Terra Grapplers, 222,000 miles, DP-Tuner Chip NS 1200 high idle stock 60Tow 80econo 120Race, 3x4" down pipe, 4" exhaust straight piped with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #4 of 5 (permalink) Old 11-18-2012, 10:35 PM
Aimless Wanderer
You can use the dealer but I have used these guys in the past with good service.
http://www.ringpinion.com/
Backslap is offline
post #5 of 5 (permalink) Old 11-18-2012, 10:42 PM
sounds good, thanks!
99.5 rear end ID for limited slip INT_MAN 1994-2003 7.3L Power Stroke 5 05-01-2010 03:45 PM
rear limited slip rebuild. buffalobob 1994-2003 7.3L Power Stroke 5 05-22-2009 05:35 PM
limited slip rear end powerstroke7.3 1994-2003 7.3L Power Stroke 8 10-16-2007 07:38 PM
rear limited slip big hunter 1994-2003 7.3L Power Stroke 1 12-17-2006 12:31 AM
Rear Limited Slip problems $trokin60 2003-2007 6.0L Power Stroke 7 07-12-2006 02:59 PM
