7.3 oil cooler rebuild - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by classic, this thread has received 4 replies and been viewed 5649 times.
post #1 of 5 (permalink) Old 11-18-2012, 08:05 PM Thread Starter
classic's Avatar
I have a 00 Excursion with an antifreeze leak @ rear of the oil cooler header. How does the cooler tube come apart from the front and rear headers so I can replace the o rings??
Violence Solves Everything
classic is offline
post #2 of 5 (permalink) Old 11-18-2012, 08:28 PM Thread Starter
classic's Avatar
I have it off the engine but figured while I was replacing the gaskets I might as well change the o rings while its off, don't know how it comes apart
classic is offline
post #3 of 5 (permalink) Old 11-18-2012, 08:54 PM
Golddigger's Avatar
You have to just pull and pry. Spray it with some pb blaster to loosen up the orings. Then lube it up with some CAT oring lube or other similar oring lube(works alot better than assembly lube or grease) and squeeze it back together.
2002 F-350 CC, Shortbed, 4X4, rebuilt 7.3, EBV brake, 4" dual exhaust, B&D compressor wheel, head studs, Gear head performance 6 pos, Banks Big Head, built 4R100 w/triple disc torque conv, Shift kit, 204K, B&W Hitch and 5th wheel companion, Superlift Air Bags, 35 x 12.50 x 17 BFG KM2:
The veiws expressed are purely opinion. I in no way take responsibility for any actions or damage as a result of trying this at home.
Local 3 OPERATORS UNION
2005 Chevy 7500 C-7/Allison, Service box off of my '93 Int
Golddigger is offline
post #4 of 5 (permalink) Old 11-18-2012, 09:11 PM Thread Starter
classic's Avatar
Thumbs up
Thanx Golddigger,, didn't wanna force it if there was a hidden clip or something I didn't see....
classic is offline
post #5 of 5 (permalink) Old 11-19-2012, 06:55 AM
hayjayhorses's Avatar
they can be tough to squeeze back together, I have put some in the press, but this is the way I like to do it, it is much easier with the truck on lift. I undo the Left motor mount bolt and put a shallow socket in between the the mount and frame to lift the engine up a bit to make some room.
remove the oil cooler assembly. pull, pry, bang it (plastic mallet) apart. clean ti ect.
to put it back together i put the install the front aluminum piece on the engine then with new o rings all lubed up I place the cooler and the oil filter converter up into place then take a 3 foot pry bar, and use the exhaust manifold as a pivit piont and push the cooler assembly all together then while holding together I install the bolts in the filter converter.
you wile have to fool around a bit to get the end of the pry bar right on the manifold
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
1989 7.3 engine oil cooler rebuild courtem 7.3L and 6.9 IDI (Pre 1994) 4 12-22-2011 02:03 AM
Rebuild a oil cooler??? International350 2003-2007 6.0L Power Stroke 10 06-18-2010 02:38 AM
Oil Cooler Rebuild DevilDocTater 2003-2007 6.0L Power Stroke 24 05-10-2010 02:38 PM
EGR / OIL cooler rebuild??????? Mike 2003-2007 6.0L Power Stroke 13 01-02-2009 03:59 AM
