1996 F350 shut off and wont restart - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by GilroyRacing, this thread has received 3 replies and been viewed 2987 times.
post #1 of 4 (permalink) Old 11-18-2012, 08:59 PM Thread Starter
TDG SinglesClub Member#90
I know its been a little while since ive been on here, but I need a little help fellas....
I was heading out the other morning.... I fired the truck up so it would warm up.. It was running for a few minutes, started ideling rough then shut off.
I figured it was the CPS so I went to the ford dealer bought another one, replaced it yesterday morning and it still wont fire up.
It cranks and sounds like it wants to fire up but just wont.
The GPR is humming like it always has (GPR109) so im sure all the glow plugs are fine, and I had it plugged up so i dont think any of that is a issue. I even checked the GPR it is showing the same volts as the batts
What else can i try or look at to get this thing running.
I also replaced the ICP sensor as well.
Here are the codes that came up... the only code im getting now is P0344..
P0344, P0472,P1280....i cleared the codes put 2 different new CPS in it and its still reading P0344....
thanks for any and all help,
Justin
1996 Ford F350, 7.3 PSD, crew cab, 8ft(Line X'd) bed, 4x4, 5 speed manual, 4.11 gears, 285/75/16 Nitto Terra Grapplers, 222,000 miles, DP-Tuner Chip NS 1200 high idle stock 60Tow 80econo 120Race, 3x4" down pipe, 4" exhaust straight piped with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers, Garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
GilroyRacing is offline
post #2 of 4 (permalink) Old 11-25-2012, 09:51 PM
Diesel Dave 04's Avatar
check fuel pressure
08 F-350 crew cab Lariat 4X4 Dually auto 4:10 gears.
rideing on Hankook Dyna pro AT's
Diesel Dave 04 is offline
post #3 of 4 (permalink) Old 12-02-2012, 11:09 PM
powerstroke expert
my guess would be chaffed cps wiring or dead idm module, but could be as simple as being low on oil. can your scan tool do KOEO on demand tests? if so do an injector electrical buzz test. if you unplug the icp sensor the pid should read 0psi until you crank for 30 seconds and the computer will default to 750psi. also does it smoke out of the exhaust when cranking?
tuning and repair solutions
7.3sootmonster is offline
post #4 of 4 (permalink) Old 12-04-2012, 12:19 PM
This is just another post where they ask for help then never return. I hate when they do this cause it dont help any one. if they come back with what it was then it helps all that read the post.
truck shut off wont restart fixitman4710 6.5L Diesel Engine 1 11-10-2011 05:44 AM
1974 TD15C WITH DT466 WONT RESTART? CLC379 Medium and Heavy Duty 1 06-07-2010 05:01 AM
Truck shut off and won't restart scotty32 1994-2003 7.3L Power Stroke 5 01-15-2010 11:00 PM
Truck died at a light & wont restart. marc21 2003-2007 6.0L Power Stroke 14 02-29-2008 03:52 PM
Truck will not restart after hot shut down JohnJohn 2003-2007 6.0L Power Stroke 3 07-11-2007 10:43 PM
