96 ford xl 7.3 psd - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by danz, this thread has received 2 replies and been viewed 1387 times.
post #1 of 3 (permalink) Old 01-16-2013, 07:33 PM Thread Starter
96 ford xl 7.3 psd
hello again,
i've asked about this problem a couple times. last time was 12/17/13. please check out that post. i ask for help this last time. the problem is injector knocking. the problem has been going on for some time, couple years. i use the truck infrequently. any thoughts on this will be appreciated.
danz is offline
post #2 of 3 (permalink) Old 02-03-2013, 03:39 AM
I found your older post. Does it still miss below 1500 rpm? Does it do it at all temperatures? Have you tried moving the injector to the other bank to see if the knocking follows it still? Are you using the same hold down bolt every time you move it? I'd maybe try and do a compression test on all cylinders. Usually its best to take out all glow plugs and test each hole, one at a time while the engine is still warm. Have you tried a shop or anything that can do a cylinder contribution test? Does it give any kind of codes?
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
The Following User Says Thank You to sdan27 For this addition to TDG:
danz (02-16-2013)
post #3 of 3 (permalink) Old 02-16-2013, 07:27 PM Thread Starter
injector knock
dan, thanks for the input. i have had a contribution test. no problems. i use the same hold down bolt for the cylinder that i am working on. have not tried moving to other bank or tested the other side for compression. will do that.the truck idles rough at lower rpm. but seems to have plenty power when i need it. i just towed a jeep cherokee and trailer with it. no problems. gets consistent good mileage 18 mpg. real head scratcher. about ready to put it on craigslist.
danz is offline
2000 Ford F250 Psd ? dieselguyoftx 1994-2003 7.3L Power Stroke 4 03-18-2010 11:44 PM
2010 6.4l psd ford excursion Jeremiah 2008-2010 6.4L Power Stroke 20 12-06-2009 10:38 PM
BD X-Monitor for 99 - 07 Ford PSD NEW in Box JacktheBear3 Ford Parts 0 11-29-2009 09:30 PM
Flashes for out of warranty Ford 6.0 PSD ichthus 2003-2007 6.0L Power Stroke 24 12-04-2007 11:39 AM
95 ford 4x4 psd $6,000 strokedout_07 Whats Been Sold 0 05-05-2007 03:47 AM
