check engine light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_hotrod, this thread has received 10 replies and been viewed 1266 times.
post #1 of 11 (permalink) Old 03-11-2006, 09:53 PM Thread Starter
check engine light
ive noticed every time i mash pedel to floor(w.o.t.) with my chip on any setting{ts 6 pos.}my service engine light comes on for a couple of minutes,whats up with this,anyone have this problem?
thanks everyone:93C_peelo
imported_hotrod is offline
post #2 of 11 (permalink) Old 03-11-2006, 10:01 PM
Supporting Vendor
How much boost are you making? If you make over 25 pounds then you will set a soft code, meaning if you keep driving easy the check engine light should turn off. Like you described. Could be setting and ICP out of range.
If you are making over 25 pounds of boost you will need something like this. http://www.itpdiesel.com/store.php?c...on=show_detail
Dave
D2 Hi-Performance
www.d2hiperformance.com
Proud to be a sponser of THE DIESEL GARAGE.COM!
(586) 709-2271
(586) 949-3234
Our rides
Dave P's Truck: 2002 CCSB 6.5" ProComp lift w/ 5100 Bilsteins, Crower Rods, Balanced rotating, coated rod and main bearings, ARP Head and Main studs, Fire Ringed, ported heads, machined and coated Mahle pistons, AFE stg II, Stealth pumps, BD's w/ 0.008 EH tips, D2HP Inconel exhaust valves, D2HP custom pushrods, Custom HX50 bolted to Hmax pedistal, Suncoast Comp trans, Detriot Electrac's front and rear, D2HP transfer case and 1 piece 4" Al driveshaft.
Dave D's Truck: 2002 ECLB Built Ford Tough Package 6" DR lift kit, Bilstein 5100's, 36x15.50R20 MTZ's on 20x10 114 Eagle's, Randy Ellis Bar w/4 8" Stainless ProComp 130W Lights, Custom tunes from DP Tuner, 05 Harley front end, D2HP transfer case and 1 piece Al driveshaft.
Becky P's ride: 2002 Limited Excursion, DVD, heated seats, TS and DP tunes, Edge Juice & Attitude, Dual exhaust, Bilstein stock replacments, AFE.
D2HP is offline
post #3 of 11 (permalink) Old 03-11-2006, 10:04 PM
Well in my opion your computer is reading something that shouldnt be there(the chip), so your computer thinks that someething is wrong with it and thats why your check engine light comes on.
PowerstrokeMan is offline
post #4 of 11 (permalink) Old 03-11-2006, 10:10 PM Thread Starter
i dont know how much boost its makin <have gauge,havent hooked up yet!!>will this part fix my problem,and will it let it ovvverbooost?and how much is it? thanks for reply
post #5 of 11 (permalink) Old 03-11-2006, 10:44 PM
RSP
Rockin-S
Its probably reading a Lower then Desired ICP when the chip is in the higher position, In other words its probably running low on High Pressure oil.
97 F350 PSD Crew Cab 4X4 Almost Stock :umno:
79 F250 CTD Super Cab 4X4 Almost Stock
79 F150 Reg Cab 4X4 Whimpy 512 CI BigBlock Some day it will be a CTD too
RSP is offline
post #6 of 11 (permalink) Old 03-11-2006, 11:10 PM
It's either this ^Above^, the overboost or both.
It's not becase the computer "doesn't think the chip should be there". If the MAP sensor sees anything above ~22psi boost, it triggers the SES light AND defuels the engine, causing a noticeable loss in power. Also, if the chip asks the stock HPOP for more oil than it can supply to run the injectors and maintain the ICP it requires, it will throw a code and the light, as stated above. If you really want to know which one, pull the codes. You definitely need the Overboost Eliminator, if it still does it with a properly adjusted overboost eliminator, it's most likely a weak HPOP.
FYI, you can make the overboost with a hanful of stuff from Home Depot.
gregrob is offline
post #7 of 11 (permalink) Old 03-12-2006, 06:21 PM Thread Starter
thanks for info-locomotion,what do i need to upgrade hpop?and where is it?and do you have a parts list for home depot!
post #8 of 11 (permalink) Old 03-12-2006, 06:28 PM
RSP
Rockin-S
Well first off what year truck do you have?
RSP is offline
post #9 of 11 (permalink) Old 03-12-2006, 07:06 PM Thread Starter
ive got a 2002 f 250 cc 4x4 w/7.3
post #10 of 11 (permalink) Old 03-12-2006, 11:03 PM
CSIPSD's Avatar
An upgraded HPOP will set you back anywhere from $1300-$2500, there not cheap! You really should pull the codes rather then just chase it around. You can make an overboost valve but there so cheap from the vendors why bother (IMO!) but to each there own... I run a overboost from dieselsite.com, but lots of vendors have them. Theres is an electronic one out but I cant remember who sells it.
Tell me your not running that without the EGT gauge!! It'll get hot quickly...
CSIPSD is offline
