95 Powerstroke IPR question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lunchbox, this thread has received 1 replies and been viewed 1662 times.
post #1 of 2 (permalink) Old 02-16-2013, 04:19 AM Thread Starter
Send a message via MSN to Lunchbox
Hey guys,
So I didn't get a response in my last post, but moving along, I think I found a potential issue.
For those that did not read the last post, I did injector O-rings, lift pump, all new rubber lines in valley, and glow plugs on my 1995 PSD.
When I took the truck apart (and removed the fuel filter canister) The IPR was "apart" (I did not know what it was at that time, but I do now). The crappy little nut had fallen off the back side, and the magnet pulled off. I see NAPA and Auto Zone call this the fuel pressure regulator, but from what research I turned up here, it looks as if this would regulate the oil pressure to the injectors as opposed to the fuel.. CORRECT?
I put it back together, but backwards.. I put the "top hat" looking spacer towards the HPOP, and the magnet on the end, then a nut.
My questions are this: Being I put this together "backwards" will it affect how it works, as the truck does run as is, however not quite right still (but has been sitting for a long while, and I am going to clean the fuel press. regulator up tomorrow in hopes to help remedy my hard start)??
Question 2: The goofy little nut that holds the magnet on is missing, so I found a suitable standard nut (1/2-20 nut threaded on perfect) and tightened it up nice and snug.. how tight should it be tightened? The magnet shouldn't be able to wobble around, right?
Hopefully someone can answer my questions this time.
Thanks in advance
Brad
Lunchbox is offline
post #2 of 2 (permalink) Old 02-17-2013, 01:36 AM
Justin@DP-Tuner's Avatar
Be sure to correct how the solenoid and spacer are. I am sure you will see a difference.
Snug is good. It needs to be tight enough to not come loose. No, it should not be able to wobble around.
DP-Tuner
For Your Tuning Needs
www.dp-tuner.com
Like us on Facebook!
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
[email protected]
IPR question tommy vestrat 1994-2003 7.3L Power Stroke 6 05-15-2011 02:11 AM
IPR Question Seafordguy 1994-2003 7.3L Power Stroke 4 04-10-2010 12:56 PM
Question from powerstroke bronco81 LB7 Tuner Forum 8 03-07-2008 06:04 PM
IPR for 1997 Powerstroke aussie ambo 1994-2003 7.3L Power Stroke 2 10-17-2007 10:42 AM
OBS Powerstroke Swap to SD Powerstroke Question Dieselwrencher 1994-2003 7.3L Power Stroke 6 12-02-2006 01:30 AM
