rough running - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97mt, this thread has received 4 replies and been viewed 765 times.
post #1 of 5 (permalink) Old 03-14-2006, 10:14 PM Thread Starter
rough running
New member seems like a great site. I have a 97 f-250 7.3 and am having trouble with around town travel, the thing acts like it is starving for fuel,it runs extremely rough(cutting out and surging) but it will run fine getting up to speed and idle well, one thing i noticed is that it will not act up if it is on cruise control at any speed. can the throttle pedal be the problem or is it something else? HELP
97mt is offline
post #2 of 5 (permalink) Old 03-14-2006, 10:28 PM
tjl
tjl's Avatar
Welcome to the site, there are a lot of good people here. I'm not sure about your problem but I've been told to clean the micro switch at the pedal to help with some of your symptoms. I'm sure some one with a lot more knowledge then me will be along soon.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #3 of 5 (permalink) Old 03-15-2006, 12:03 AM
CSIPSD's Avatar
How many miles? Have you changed the fuel filter lately? Could be a fuel pump, or valve cover harness is working loose. Maybe fill out your signature some so we know what you've done. Welcome
CSIPSD is offline
post #4 of 5 (permalink) Old 03-16-2006, 01:02 AM
It could be that a fuel sensor is out of it. Have you checked the fuel sensor? It also could be the injectors.
Nobbe15 is offline
post #5 of 5 (permalink) Old 03-16-2006, 02:13 AM
It could be any number of things. I'd try to get it somewhere where they can hook a scanner up to it and see if there are any DTCs stored in the PCM. Also have them run a cyl. contribution test on it and a buzz test to check out the injectors.
gtspowerstroke is offline
