Insulation on Intercooler tube? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Ghostrider304, this thread has received 20 replies and been viewed 4469 times.
post #1 of 21 (permalink) Old 03-18-2006, 01:06 AM Thread Starter
S.L.A.P.S. Sgt. at Arms
Anyone remove the insulation from the intake side boost tube? If so how hard was it, and what did it take to get the glue crap off? Also, did you paint the tube or polish it? If you painted it what brand of paint works best?
I know this is a lot of questions for one post, but I'm sure you guys can handle it.
Oh, one more thing. Will the duplicolor Meatalcast paint work for this project?
Thanks,
Will-
William Haskell :evil:
FORMER SLAPS-"[email protected]" Member #12
#47
2006 Dodge 2500 Mega Cab 4x4
2001 PSD 4x4Sold
The wife's ride.
2005 Ford Excursion Eddie Bauer 6.0 Ltr PSD, White over Gold. SOLD!!!!
Ghostrider304 is offline
post #2 of 21 (permalink) Old 03-18-2006, 03:25 AM
4cstr
Good question. My early 99 didn't come with insulated CAC tubes...but I'd be interested in hearing about the paint as well. I know that powdercoating is probably preferred...but will a paint work as well.
post #3 of 21 (permalink) Old 03-18-2006, 03:28 AM
The best way to do the project is:
1. You need to get the "tin foil" stuff off kinda like skinnin a deer or what ever your flavor of game, use a putty knife or razor knife and seperate the tin foil and insulation from the pipe
2. Spray the pipe down with NAPA decal and paint remover or gasket remover, let it sit for a while......then use a preasure washer to blast the glue off, or use a scotch pad and scrub it off....preasure washer is easier
3. Wipe down with MEK (Methol Ethol Ketone) or Acetone to remove any Residue then with paint thinner and paint with your choice of paints, I just left mine plain to match the other side.
DieselDan is offline
post #4 of 21 (permalink) Old 03-18-2006, 04:40 AM Thread Starter
DieselDan,
Thanks for the info.
Does the paint need to be heat resistant to a certin temp?
Thanks again,
Will-
#47
2001 PSD 4x4Sold
The wife's ride.
post #5 of 21 (permalink) Old 03-18-2006, 02:28 PM
Dont know I just left mine bare to match the other side
post #6 of 21 (permalink) Old 03-20-2006, 05:55 PM
FORD For Off Road Driving
Muddin's Avatar
You can paint he tubes after you prep them like mentioned. I painted both of mine about 2 yrs ago and they are holding up fine!! I used regular automotive paint but I suggest a high temp clear coat!!! other than that, it's pretty easy!!! Tape the ends up so that ya dont get any paint inside em though!!:Thumbup:
Muddin
Truck #1 info: Early '99, 7.3L PSD, 4x4, Ext. Cab.
Mods: BTS TRANNY!!, DP Tuner, Rockwell 2 1/2 ton military axles!
Truck #2 info:'02, 7.3L PSD, 6spd, 4x4, DRW, CC.
Mods: B&W gooseneck hitch
Muddin
Muddin is offline
post #7 of 21 (permalink) Old 03-20-2006, 05:57 PM
Muddin's Avatar
here's a link to a pic of mine that are painted. they are pianted charcoal grey.
Muddin
http://fordtruckworld.tenmagazines.c...14&album=28373
Muddin
Muddin is offline
post #8 of 21 (permalink) Old 10-12-2006, 09:12 AM
Question, I had heard that if you removed the foil you got extra turbo noise, is this true?
I saw it on this thread- http://www.powerstroke.org/forum/showthread.php?t=4769
Is that true? If so i'll do it.
~CrazyDiesel~ is offline
post #9 of 21 (permalink) Old 10-12-2006, 12:36 PM
what does not kill you ..
I removed mine and could not tell any difference. The insulation is the ugliest thing
wftree
1999.5 F450 CC 4x4 315HP/709tq 6 speed with BD short shifter; DP chip: stock, , high idle, 40tow, 80econo, 80 tow, 100, 140,South Bend clutch; ported BB turbo; SPEARCO 6.0 charge air cooler; pop off valve; dieselsite I/C boots; 203 degree thermostat; pillar mounted pyro, boost coolant temp guages; HX hose; shimmed regulator; Tymar intake; zoodad; 4" DP to 4" exhaust to Aeroturbine muffler to 4" chrome stack; Dahl 100 heated fuel filter; in tank/pre pump mod, Hella FF driving & fog lights, Ford of Ocala SUCKS!
WORK TRUCKS '90 F450 7.3 flat bed, '90 Inter 7.3 flatbed, '96 F450 7.3 dump, '96 F800 5.9 Dump, '00 FL60 Cat Lift truck, '02 F150 5.4 pickup, '04 F550 6.0 Dump, '04 f350 6.0 pickup, '07 F550 6.0 Flatbed, '04 f450 dump
wftree is offline
post #10 of 21 (permalink) Old 10-12-2006, 04:54 PM
CSIPSD's Avatar
It was added by ford in the late 99's due to complants about noise, also why they changed turbos...
I just removed what I could pull off and then used a wire wheel on a grinder... took about 10 minutes. Painted mine red and will get them PC'ed at some time. Paint works fine thou...
ID:	6860   Click image for larger version
CSIPSD is offline
