Cruise control problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by diesel_demon, this thread has received 8 replies and been viewed 1035 times.
post #1 of 9 (permalink) Old 03-20-2006, 09:52 PM Thread Starter
Post Cruise control problem
Im trying to find out some info for BigStroker his truck is having a cruise problem it want set and none of the fuses are blown. the brake lights work also but for some reason the back up lights are out:shrug: .
Thanks,
Chris R.
diesel_demon is offline
post #2 of 9 (permalink) Old 03-20-2006, 10:09 PM
tjl
tjl's Avatar
I don't know about the backup lights but I had problems with my cruise also. At first it would work for a while then stop and then it quit all together. It ended up being the brake switch on the front of the brake master cylinder. I removed the switch and it was full of brake fluid. It is a 5 minute repair and it fixed my problem.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #3 of 9 (permalink) Old 03-20-2006, 10:11 PM
yeah, mine quit working today too....
~CrazyDiesel~ is offline
post #4 of 9 (permalink) Old 03-21-2006, 01:57 AM
New member, old guy
Mine did the same thing and it wound up being the plugs on the back side of the horn/cruise pad where the two wires attach. Cleaned things up and reconnected, been fine since (a couple months so far).
Dave / Believer45
'95 F250 power stroke 5 spd 4x2, extended cab, long bed, 3:55 rears, open air filter, 285/75x16 Cooper ATR tires, Putco master boss running boards, aluminum cap on bed, custom rear bumper (@350 lbs additional weight), scale weight full of fuel, me in it (285#) - steer 3420 drive 3160 gvw 6580, fast approaching a half million miles.
Believer45 is offline
post #5 of 9 (permalink) Old 03-21-2006, 03:39 AM
Yea, mine is all over the place. Sometimes it works flawless, sometimes it dies randomly. I drove to Colorado and it did it maybe 4 times. Kinda irritating. The most it has ever stopped working at one time was after I installed my intake, it didnt work for about two months, then it went away. Not sure why, maybe i bumped something.
00turboPSD is offline
post #6 of 9 (permalink) Old 03-21-2006, 12:03 PM
mine dont work either
DBogo is offline
post #7 of 9 (permalink) Old 03-28-2006, 02:30 AM
n2diesel's Avatar
I just noticed my stopped working yesterday. It had been working before
n2diesel is offline
post #8 of 9 (permalink) Old 03-30-2006, 12:32 AM Thread Starter
I found out what it was it was one of the 15amp fuse in the fuse panel under the hood. I replaced it and the reverse lamps started working and the cruise.
Thank all yall for the help,
Chris R.
post #9 of 9 (permalink) Old 03-30-2006, 04:22 PM
FORD For Off Road Driving
Muddin's Avatar
Mine is not working either. It quit for a while and then I reset the computer and it started working again. Now it quit and it does not fix it to reset the PCM. What do yall think? I was told there are some wires in the steering wheel that can break if you turn the wheel too far.
Truck #1 info: Early '99, 7.3L PSD, 4x4, Ext. Cab.
Mods: BTS TRANNY!!, DP Tuner, Rockwell 2 1/2 ton military axles!
Truck #2 info:'02, 7.3L PSD, 6spd, 4x4, DRW, CC.
Mods: B&W gooseneck hitch
Muddin
Muddin is offline
