anyone have wiring diagram for dash harness? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by guardrail, this thread has received 5 replies and been viewed 472 times.
post #1 of 6 (permalink) Old 03-22-2006, 03:21 PM Thread Starter
barely smokin'
Send a message via AIM to guardrail
I've got this electrical gremlin from when the previous owner had the dash out. The BCM is setting a code and some systems (door locks, ajar circuit..) aren't working I think because of it. The Code is something to the effect of the positive battery signal is missing from the BCM. I think I've got a main power feed missing or something. I'd like to see if I can start tracking down some of these circuits.
02 F250, CC/LB/4x4 4" lift w/ 35's
Straight pipe, barely smokin'
AFE Stage 1
guardrail is offline
post #2 of 6 (permalink) Old 03-25-2006, 04:40 AM
Interesting. If you have the shelf space you can pickup the 2001 f-series blueprint size diagrams on ebay now and then for about $20.
RacerX is offline
post #3 of 6 (permalink) Old 03-25-2006, 05:31 PM
What is this BCM module you are reffering to? What is the code? Is it maybe the VCM?
250stroker is offline
post #4 of 6 (permalink) Old 03-25-2006, 07:31 PM
Have you checked all the fuses?
gtspowerstroke is offline
post #5 of 6 (permalink) Old 03-27-2006, 09:10 PM Thread Starter
barely smokin'
The body control module, or whatever ford calls it, I believe it's mounted up on the back side if the firewall behind the dash on above the transmission hump.
All the fuses are good, just have some things not working properly. I'll hook up the edge and read the code when I leave work tonight.
AFE Stage 1
post #6 of 6 (permalink) Old 03-28-2006, 05:16 PM Thread Starter
barely smokin'
code is P0603 Powertrain Control Module Keep Alive Memory Error. I was thinking this may be related to my electrical issues if the computer is missing some sort of power, but since it runs fine and sets no other codes I don't believe the two issues are related.
AFE Stage 1
