911!!! help please - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by willjohns, this thread has received 4 replies and been viewed 1371 times.
post #1 of 5 (permalink) Old 08-12-2013, 11:44 PM Thread Starter
911!!! help please
so about six months ago my 97 f250 4x4 psd with 300,000mi started spitting and sputtering like it was running out of fuel, finally quit.m hauled it home, so far, changed ipr, icp, cps, fuel pump, fuel filter, tested hpop and noticed when i block off the pass side hpo line truck will crank and run (as good as one will on just four cyls) so i replaced orings on all eight injectors and no change, hpop res stays full, fuel bowl stays full, checked all wiring, now im pulling out all of my hair trying to figure this one out, to the point of lying in the fetal position and crying
willjohns is offline
post #2 of 5 (permalink) Old 08-13-2013, 09:55 PM Thread Starter
Come on guys i need help!!helps
post #3 of 5 (permalink) Old 08-14-2013, 03:03 AM
bpogue's Avatar
Were you showing any codes before it died on you? Are the injectors original?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #4 of 5 (permalink) Old 08-14-2013, 03:06 AM Thread Starter
Original injectors and the cel came on but went away after it died but no saved codes
post #5 of 5 (permalink) Old 10-17-2013, 05:52 AM
Hey by any chance before she died do you remember what the exhaust was like ? Blue ? White ? Just thinking maybe the drivers side hpo line could have a crack n won't allow that hpop to build enuf pressure.
Dutchy is offline
911 no o/d no lock up. Orangepstroke 5.9L Cummins 12 Valve (1994-1998.5) 4 03-13-2011 06:00 AM
911 Has anyone seen this before? bgtony1 Euro-Diesels 1 11-10-2006 12:14 PM
My encounter with a 911 .... frequentflyer 2003-2007 6.0L Power Stroke 9 12-27-2005 12:41 AM
911 I Need Help StrokerAce Duramax 2004.5-2005(LLY) 4 11-06-2005 03:51 PM
