1999 fuel pump wiring has 6.7 volts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Johnp3, this thread has received 3 replies and been viewed 1029 times.
post #1 of 4 (permalink) Old 11-10-2013, 06:51 PM Thread Starter
The 7.3 fuel pump on the left frame rail was replaced recently, I tested the power to the pump it has 6.7 volts, checked at the kill switch, I have 6.7 volts there I can not find the relay or trace the wire back to the sourse.
Johnp3 is offline
post #2 of 4 (permalink) Old 11-12-2013, 10:26 PM Thread Starter
I figured it out.
Johnp3 is offline
post #3 of 4 (permalink) Old 11-13-2013, 02:47 AM
bpogue's Avatar
what did you find?
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #4 of 4 (permalink) Old 11-13-2013, 06:41 PM Thread Starter
It is trace voltage, the pump had 450 OHMs resistance, new is .5 OHMs. The power control modual, sends out the voltage to check the circuit, if it is OK then it grounds the relay sending full power.
It took a while to figure all this out as information is hard to find.
Just a thought!
Johnp3 is offline
The Following User Says Thank You to Johnp3 For this addition to TDG:
bpogue (11-14-2013)
1999 N-14 Celect fuel problem milkman Medium and Heavy Duty 6 07-06-2013 03:29 AM
Wiring on 99 24v p pump conversion Micheal 5.9L Cummins 12 Valve (1994-1998.5) 1 01-31-2009 10:36 AM
1990 5.9 ip pump wiring exoticsrnw Dodge Performance Forum 0 03-11-2008 05:47 AM
Help! Ran out of fuel 7.3 diesel 1999 RyanKFordvan 1994-2003 7.3L Power Stroke 3 12-05-2007 02:48 AM
ACCEL 110GPH Fuel Pump/Lift Pump maxxis_mudder Whats Been Sold 0 12-10-2006 03:24 PM
