1995 Powerstroke excessive smoke - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lunchbox, this thread has received 3 replies and been viewed 1271 times.
post #1 of 4 (permalink) Old 11-23-2013, 03:27 AM Thread Starter
Send a message via MSN to Lunchbox
Hey guys,
A while back I bought a 1995 Powerstroke that was putting fuel into the oil/smoking excessively.. Truck has 180xxx miles it.
What I have done so far:
Injectors were tested (all passed) and were re o-ringed
New injector cups
Found one "dead" cylinder, re-rung engine (all cylinders have around 400 pounds compression since re-ring at crank speed)
New fuel pump in valley
Cleaned out pressure regulator
New fuel filter
Now it smokes.. Much more than a haze.. Looks to be a white smoke. Seems to run fine, don't seem to be short on power. Smokes whether the truck is cold or warm. Smokes from start-up to shut down.
What am I overlooking?
Thanks in advance,
Brad
Lunchbox is offline
post #2 of 4 (permalink) Old 11-23-2013, 06:10 PM
I am not an expert in the power strokes, but have worked on a few of them, You want to test all the glow plugs, I found that it takes very few not working to cause smoke at start up and loading the engine with fuel in the exhaust and the crankcase. It will then draw in extra fuel, from the crankcase breather, and burning off in the exhaust. I take it you have changed the valve cover gaskets. You can go onto the GB remanufaturing to get the pin outs from the injection actuator modual, looking for a poor conection.
Just a thought!
Johnp3 is offline
post #3 of 4 (permalink) Old 11-23-2013, 07:26 PM Thread Starter
Sorry, I should have added that drivers side bank had a newer gasket etc when I purchased the truck (receipt from local NAPA was dated less than one year before I purchased the truck, and I know the truck had been sitting for 4-5 months when I purchased it for the gasket and 4 glow plugs and labor to install them.. You'd have to go back to my posts from long ago, but I bought this truck from a very good friend who had parked it after it started putting fuel into the oil pan)
I myself replaced the passenger side gasket when it was re-rung (one of the connectors was wiped out) and replaced the 4 passenger side glow plugs and tested all per service manual when motor was put back into my truck.
The glow plug relay is also NEW.. I somehow managed to crack the old one while setting the engine back into place.
I'm starting to feel like I been throwing money into a boat anchor here..
Brad
Lunchbox is offline
post #4 of 4 (permalink) Old 11-24-2013, 12:22 AM
Aimless Wanderer
Brad
I really hate to say this but some of the early power stroke blocks liked to crack in the fuel gallery/passages and gave the same problems you are experiencing with fuel in the engine oil. Your year is among them.
There is a test kit for this from the Ford Service "Rotunda" group that pressurizes the fuel system and the problems/cracks were found with soap bubbles, and a timed "leak off" test.
I'd ask a Ford service garage of the direction to follow. The service replacement blocks at the time were readily available but there are a few changes through the years so don't quite know what would be required with yours' if the problem is as suspect.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
Got a ticket for excessive fumes/smoke toylet 2008-2010 6.4L Engine Tuner Forum 46 10-10-2009 04:08 AM
Excessive smoke!! sstockton 5.9L Cummins (1998.5-2002) 30 12-27-2007 09:31 PM
2004 6.0L Hesitates and excessive black smoke 04Stroker 2003-2007 6.0L Power Stroke 14 07-25-2007 10:30 PM
06-13-3 Misfire, Lack Of Power, Buck / Jerk, Excessive Smoke, Crank / No Start - 6.0l Squatch Ford Oasis requests 0 03-22-2007 03:04 AM
excessive smoke, tune issue? SICKS-O 1994-2003 7.3L Chips & Tuners Forum 19 06-23-2006 01:37 AM
