35-40 mph shudder and hop - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cory5517, this thread has received 5 replies and been viewed 1692 times.
post #1 of 6 (permalink) Old 12-01-2013, 08:06 PM Thread Starter
I have this shudder and hop at half throttle and have replaced the following: all rear u joints and carrier bearing, tires, and throttle positioning sensor. Anybody else experience this same problem and have a solution? Thanks in advance
cory5517 is offline
post #2 of 6 (permalink) Old 12-03-2013, 06:52 PM
You have to tell us what truck you have, the more information you can give the better the answers will be.
First thing you want to check is the Phasing of the drive shafts. Also if you have a 4x4 then you must jack it up, even with hubs, the "U" joints can sieze and jerk the steering.
Just a thought!
Johnp3 is offline
post #3 of 6 (permalink) Old 12-03-2013, 07:37 PM Thread Starter
My truck info should be in my garage. What do you mean phasing of driveshaft?
cory5517 is offline
post #4 of 6 (permalink) Old 12-03-2013, 11:12 PM
Weld engineer's Avatar
Make it easy on everyone and put it in your signature or in the details of your thread. Since everyone is a working for free here you won't get much by telling guys to go on a search to assist you. Just some free advice.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #5 of 6 (permalink) Old 12-03-2013, 11:28 PM Thread Starter
I think I figured out the signature
2001 f250 ccsb 4x4 7.3 with 4r100 transmission. Riffraff 6637 and HPX. Pioneer avp-1400. Warn lockouts. Mbrp 4" straight pipe exhaust. 265/75/16E cooper discover ATP. Ranch hand front and rear replacement bumpers. Cobra 29 Bluetooth
cory5517 is offline
The Following User Says Thank You to cory5517 For this addition to TDG:
Weld engineer (12-04-2013)
post #6 of 6 (permalink) Old 12-04-2013, 05:23 PM
Phasing of the drive shaft is the "U" joints are alighned properly the cross on the diff and the cross at the steady bearing must be in the same position, the "U" joint at the transmision is 90 degrees from that.
If the drive shaft is out of phase it will try and straighten itself out on every revolution.
Just a thought!
Johnp3 is offline
shudder??? swnrcng530 2003-2007 6.0L Power Stroke 6 06-29-2010 11:49 AM
Shudder fordfanatic69 2008-2010 6.4L Power Stroke 7 06-13-2009 08:48 PM
Shudder on take-off spgtti72 General Ford Truck and Excursion 7 02-10-2008 12:40 AM
07-5-11 Vibration/hop At 40-48 Mph (68-77 Km/h) - (8.0 Hz) - Trailer Hitch Equipped V Squatch Ford Oasis requests 12 11-21-2007 02:48 AM
Shudder bean.d 2003-2007 6.0L Power Stroke 18 10-03-2006 08:37 PM
