PCM Swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kblackav8or, this thread has received 14 replies and been viewed 2698 times.
LinkBack Thread Tools
Old 04-04-2006, 02:35 AM Thread Starter
I do all my own stunts
Send a message via MSN to kblackav8or
PCM Swap
Has anyone done this and not had an issue? I just swapped a XPC4 for a APX1. I now get a code for high coolant temp that won't clear. Looking for a near free 40 horsepower.
2000 F-250 PSD 6 speed 4x4 Lariat
1959 Kenworth CC 925 NTC-400 5x3 4.10 SQHD's
Myriad of parts and pieces in my garage
kblackav8or is offline
Old 04-04-2006, 04:51 AM
you need to swap a xp pcm with an other xp. you wont get rid of temp code useing ap pcm, unless you have it programed. if i remember right?
imported_diesel71 is offline
Old 04-04-2006, 04:55 AM Thread Starter
What if I chip it? Am I going to hurt the truck? Can I get it reprogrammed permanently?
Old 04-04-2006, 05:03 AM
permanently yes, not sure what it will do long term? if your looking to chip it just use the xpc4. if you need hp thier is alot of cheep mods you can do.
Old 04-04-2006, 05:45 AM Thread Starter
I was going to keep my stock computer stock and use this one to do whatever with and not worry if I ever had to deal with warranty stuff in the 35k left on the engine.
Old 04-04-2006, 06:17 AM
: try your local auto recyclers for a pcm match? or maybe ebay?:Thumbup:
Old 04-04-2006, 06:37 AM
4cstr
Put your stock pcm back in...then ship your extra pcm to Jody and Diane at DP Tuner..they are a supporting vendor. Jody can reprogram your pcm to your wishes...as long as its within the same family of cpu's...if I remember correctly.
Some trucks are finicky with swapping pcm's. My truck is an XLE8 truck, and I swapped in a PMT1 pcm. The shift strategy was awesome...but when hooked up to our camper I kept setting the SES light for an overboost. My gauges tell me otherwise. I put an XLE8 pcm back in and my troubles have gone away.
Old 04-04-2006, 06:52 AM
:agreed: :agreed:
Old 04-04-2006, 07:39 AM Thread Starter
So can they reflash my "spare" to be an XPC4 with the higher power of the 01' MT trucks? Or just reflash as a stock XPC4 plus a 3-4 position chip. Amazing how little there is in that box. Anyone tried a Tweecer on their PSD?
Old 04-04-2006, 01:05 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
kblackav8or,
I would put the XPC4 back in and not use the APX1. They are not from the same DCP-??? family of codes. The APX1 PCM can not be flashed to make it a XPC4. If you are looking for a PCM to chip we have a DPC-421 or XPC4 in stock. That way you can keep your old PCM stock.
SeeYa is offline
