Funny Noises - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TBoy34, this thread has received 1 replies and been viewed 581 times.
post #1 of 2 (permalink) Old 03-20-2014, 01:33 AM Thread Starter
Funny Noises
Hey everyone,
My truck keeps making a pretty hard grinding noise from under the floor boards lately, it only happens when i let off the throttle and the truck holds the gear and brings the rpms down, it grinds for a second then stops. Im also getting a pretty bad grinding from the four wheel drive whenever the t case is engaged, doesnt do it if just the hubs are locked. The owner before me had just put the front driveshaft in before he sold it to me, but it didnt make the grinding until after about a month of driving it...any ideas!? Could the driveshaft be the cause of both noises?
TBoy34 is offline
post #2 of 2 (permalink) Old 03-20-2014, 07:56 PM
Check the oil levels and the motor and transmission mounts, be sure everything is tight, transmission to engine and transfer case to engine. Be sure the front drive shaft is not bottomed out. If it is too long it will make all kinds of weird and wonderful sounds. It might be an idea to drain the transfer case and front diff, looking for abnormal metal.
Just a thought!
Johnp3 is offline
Noises Operator 1994-2003 7.3L Power Stroke 8 08-16-2007 06:25 AM
Normal noises?? craustin 2008-2010 6.4L Power Stroke 8 06-27-2007 12:06 PM
Turbo making funny noises THEMADTYPH00N 2003-2007 6.0L Power Stroke 7 09-06-2006 05:11 AM
What are those noises?? iberiarhino Duramax 2006-2007(LBZ & LLY) 1 08-03-2006 09:15 PM
New noises? boggerman 2003-2007 6.0L Power Stroke 12 06-04-2006 10:22 AM
