Boost leak test rig... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CSIPSD, this thread has received 2 replies and been viewed 542 times.
post #1 of 3 (permalink) Old 04-09-2006, 04:34 AM Thread Starter
CSIPSD's Avatar
Got to find this pesky boost leak !!! So I built a little rig to make it an easier job! Found a few easy ones, one on the boost regulator and two for the water injectors. The water injectors had worked the Al Y pipe and opened up the tap job I did:shrug: ... They are JB welded in there now:evil: !!! Will be looking for more tomorrow once the JB has set up!!!
Once I find a new Y pipe I will weld some threaded bungs in there!:Thumbup:
Name:	air regulater.JPG
ID:	4770   Click image for larger version
Name:	leak tester.JPG
CSIPSD is offline
post #2 of 3 (permalink) Old 04-10-2006, 01:17 AM
hay thats a nice lookin set up what exactly did you use?
DieselDan is offline
post #3 of 3 (permalink) Old 04-10-2006, 04:42 AM Thread Starter
CSIPSD's Avatar
It's an ABS "street"(sp?) 45 with a cap, I drilled and tapped it then made a regulater set-up and another male connection. That way I can just hook it up and start spraying soap everywhere !!!
About $8 in parts, but small enought stuff to just drop on the company account: !!!
CSIPSD is offline
